2017 sreetglide using some oil
Mine was losing about half a quart per 5,000 miles but since I passed 10K it's either eating a lot less or none at all now.
By the way, ymmv but my local dealership told me that Harley Davidson wouldn't address any oil consumption problems unless the bike was using more than 1 qt per 1,000 miles. Anything less than that was considered "within acceptable limits."
Oh and also, by the way, "one dot" on the dipstick represents approx. 3 oz of oil
MotoJockey (06-24-2017)
From what I recall, back in the days when car engines tended to burn more oil, that was the magic rate of tolerance in the warranty. But, I really wouldn't want any of my motors to use that much. As a comparison...oil consumption via bad valve seals was the root cause of engine failures in Vegas. The oil level would go down, due to leakage around the valve seals. Then if the owner didn't keep up with adding oil, the cylinder walls would score...then it would really burn oil more rapidly...leading to more damage due to low oil. BTW, by checking the oil level in my 1974 Vega regularly, I got 105,000 miles on it with no engine work. Too bad the entire body rusted off in upstate New York.
m8 using oil
I run my oil 3 dots down hot and 5 dots down cold. I have oil in air box and in the throttle body. Could this have maybe caused the rings not to seat when new?have 3000 mi on bike now and it still uses some oil which is in the intake. Seems like a ring issue to me but i am old school. Thanks. Dennis
Low 1quart
Did my first oil change at 1400 miles, my M8 was low 1 quart of oil and the transmission was reading way below low. Around 500 miles I installed Vance and Hines power duels, rineharts amd FP3, according to the settlement agreement Harley signed with the department of justice I voided my warranty by remapping the bike and installing power duels, therefore I skipped the $500 first service and changed all the fluids myself with synthetic for $66.00 including oil filter.
