Is it just me...
I've noticed there seems to be similar observations and comments here as of late..early on I looked into SuperTrapp Kerkers and found this clip, which made me want the Slash for their deeper lower tone..but just went the safe route with the SE Canons to compliment the SE Stage 1 completion...it's worked out great performance wise, can't say the sound is exactly what I wanted but has grown on me and actually like them now
not you.. I went through the same thing when I was looking into aftermarket exhaust. All of the popular brand mufflers sounded the same unless you completely removed the baffles. I really couldn't find anything that wowed me..
Then when I swapped the head pipe for catless headers things changed. It made a huge difference. Even the SE street cannons, which are now on a shelf, sound great with the V&H power duals. I just might swap out the Eliminator 400 mufflers for the street cannons.. (because of the slant cut end pipe that I believe matches better with the stretched saddlebags)
Received 14,138 Likes
Most if them do sound very similar especially if the catalytic converters are still intact.
One set of slip ons that did sort of stand out when I was listening to you tube clips is the S&S MK45.
Regardless the M8 does have its own sound that is probably more like a vrod than a shovelhead.
mjwebb (06-26-2017)
M8 owners keep searching for that old sound they had on previous twinkies,but hard to duplicate with the M8. A camshaft change,new true dual header pipe with the slip on's might get you there.
https://www.youtube.com/watch?v=9rfWJRXSDBo
mjwebb (06-27-2017)
Don't fool yourself into thinking slip-ons will cure all you sound woes. They will improve the sound though. In my case I used V&H twin Slash Rounds. I find a much better improvement in the sound, but certainly not obnoxious. that was fine with me since that's what I was looking for, for this particular bike.
Also, here's a tip. When listening to comparisons on videos, make sure to use ear buds !!!! That makes a major difference and gives you a much clearer picture of what they really sound like.
