Fog light dash lights
In the tachometer gauge, you have a blue high beam light and to the right you have a green fog light indicator. When I first got bike when fog lights were on, both the green light in the tach area and the toggle button light to the left on the ignition switch would illuminate. Now the light on the dash is not functioning. Called two dealers and both said there is not a green light in that area. The local dealer was looking at me strange until we went into the show room an turned on some ignitions. Low and behold a green light next to the blue high beam! They are clueless. Anybody else have this little nuisance of a problem? Not a big deal just wondering if it is a warning sign of bigger issue.
cmastrom (07-22-2017)
I am aware that when brights go on, fogs go out. Green indicator light on dash should be on when fogs are on. Mine were at first, now it does not illuminate.
on my 2016 SGS there isn't a light for the aux lamps I asked the dealer when they were installed , but our 2017 Ultra Tri Glide does you would think the tach on both models would be the same hope this helps , and the dealer programmed the SGS so the aux lamps work on high and low beam
He was not aware of it until i mentioned it.
cmastrom (07-25-2017)
I installed the Aux lights on my 17 and they stay on with the high beams.. Was gonna get dealer to turn gauge light on, but doesn't bother me.. Little switch lights up so I'm good
