oil in air cleaner on 2017 streetglide
O K Had to steal M J s photos but the replacement pipes are elivated so the oil Vapour should go directly into the intake vacuum path through the inlet valves and into the engine.The mounting tabs are fixed to the new pipes so it is remove,plug and play.The yellow snot does not come out of the engine it is an emulsion of oil Vapour and steam which is actually produced in the catch can!
the picture shows the old tubes but when you go to the Guide tab and click on instructions the images and part numbers show the new ones
rscott (01-28-2019)
I have this issue with my 2017 SGS and looking for a fix, but am confused by your pictures. I've got the SE high flow air cleaner kit - wedge, bike not accessible right now to see where my tubes direct overflow to (top or bottom of butterfly).
Are you staying there are new tubes I can buy that will put them to the top of the butterfly? And if so, do you have a part number?
Jeff1759 (01-27-2019)
This what I ended up doing for my 2017 SGS,,, a little over kill but I worked with what I had,, now no more oil/water on the engine etc... I put a small removable expandable drain plug on the bottom to drain it when necessary,,,, there is a ton of pics and people willin to help on this forum regarding this issue just look around a little bit,,Have fun
Why don't you all just get a DK Customs external breather kit & be don w/this mess...??
http://www.dkcustomproducts.com/all-...es-c76-180.htm
Small investment, but corrects the issue...
It'd be nice to trust the dipstick.
