Fullsac MX Header pipe
This is one of those things you pay for what it really does. Here is a test of the new FULLSAC MX headpipe. Bike is a 2017 107 Oil Cooled RK.
Run 13 fully tuned with stock head pipe 5th gear
Run 19 fully tuned with FULLSAC MX head pipe 5th gear
Run 20 fully tuned with FULLSAC MX head pipe 6th gear
All runs SAE, same day same dyno same tank of fuel. No changes to anything else on the bike during testing and the same mufflers used for all testing.
Seems to have smooth transitions through out the entire head pipe.
Sure that will help with temp, flow and future engine mods.
The price is very comparable to other systems. I agree with the 700 being more than anticipated. I want quality for cheap, but quality is never cheap, it is affordable however.
I agree somewhat with what you are saying. Reading several dyno sheets all across the board between 2/1 and 2-1-2, with the right combination they are all relatively close in numbers.
High Flow AC
OEM head pipe
Fullsac re-cored factory mufflers
TTS 150 camshaft
Mastertune
After
High Flow AC
Fullsac MX head pipe
Fullsac re-cored mufflers
TTS 150 camshaft
Mastertune
Running summer blend Chevron Premium (91 so they claim) octane pump gas as this is all we have in CA. In the midwest and east you guys can get better gas than us which typically allows for slightly better power to be made from the same components.
Bike is your typical Stage II 107
High Flow AC
OEM head pipe
TTS 150 camshaft
Mastertune
After
High Flow AC
TTS 150 camshaft
Mastertune
High Flow AC
OEM head pipe
TTS 150 camshaft
Mastertune
After
High Flow AC
TTS 150 camshaft
Mastertune
Is there a good number to call Monday and talk about header, the Az number on the website?
