3 oil hole design
3 oil hole design
A genuine question, as the M8 is a totally new engine did the HD engineers miss the chance to design a single oil in / single oil out system or is the 3 hole way, better ?
Not having a go at HD , just wondering?
Oil migration between trans and primary wouldn`t be an issue then.
Separate drive train makes $ sense and increases ease of upgrades. It's all about making money, but if you want to upgrade your trans but not your motor, you can do so and vise versa. Considering Harley advocates using the same oil in all 3 holes, oil migration isn't really an issue, especially from trans to primary. You should check your fluid levels often anyhow.
fullautomike (09-07-2017)
Personally, I also like the 3-hole design. In addition to keeping clutch matter out of the mail crankcase oil, it isolates the three systems from any cross-contamination. Too, it offers the ability to run different oil for different purposes, i.e. running more "transmission oriented" oil in the tranny, etc. For me, I run dino in the trans and primary, and Syn3 in the crank. YMMV.
