M8 optimal rpms at cruise
Old 08-28-2017, 08:37 AM
smitty901's Avatar
smitty901
smitty901 is offline
Received 9,557 Likes on 5,153 Posts
Originally Posted by alburton
I read an article once that the stated that you should run your engine at the max torque RPMs. In our case 3,250 RPM. His reasoning was that at max torque RPMs the engine is running at it's highest efficiency. That being said, I cruise in 5th if I'm cruising highway speeds less than 110 km/h; 110 km/h and over 6th. That puts me right around 3,000 RPM.....Al
You have been grossly mislead. That is the nicest way I can put it.
Another Old Timer (06-12-2019)
Old 08-28-2017, 08:49 AM
teedoff65's Avatar
teedoff65
teedoff65 is offline
Received 1,464 Likes on 1,057 Posts
How are some of these guys seeing such high rpms?? I see ppl posting stuff like....I run around 60 mph in 5th gear and the rpm is up around 4000.
I run 60 in 5th all the time and the rpm's stay well below 3000. Heck, even in 4th gear running that fast, I dont think I break 3 grand. Of course if you're constantly WOT, I can see that. I think some ppl like to exaggerate. lol
Unless I'm on the highway, I rarely run in 6th gear.
Old 08-28-2017, 08:51 AM
mjwebb's Avatar
mjwebb
mjwebb is online now
Received 8,492 Likes on 4,409 Posts
between 2500 and 3000 seems best, I try not to dip below 2500 but honestly a little lower doesn't lug my engine and that's the most important thing, knowing the sweet spot ..when the speed limits are high on a long road trip you forget about rpms and do whatever 6th is doing obviously
Old 08-28-2017, 08:53 AM
rjmac53's Avatar
rjmac53
rjmac53 is offline
80% of redline. If redline of M8 is 5500rpms then 4400 rpms in any gear is considered optimal range for engine performance, not comfort.
Old 08-28-2017, 08:55 AM
teedoff65's Avatar
teedoff65
Originally Posted by rjmac53
80% of redline. If redline of M8 is 5500rpms then 4400 rpms in any gear is considered optimal cruising....
What??? I hope you're being facetious.
smitty901 (08-28-2017)
Old 08-28-2017, 08:58 AM
PDB17UltraRG's Avatar
PDB17UltraRG
PDB17UltraRG is offline
2500 to 3500 is were i like to be works well for me. Any higher and your just sucking up gas or just having fun riding fast. Just like others have stated 6th gear 3000 rpm happy happy happy
draper12 (10-12-2023)
Old 08-28-2017, 08:59 AM
Firebolter's Avatar
Firebolter
Firebolter is offline
Originally Posted by jclax01
I just did 1200 miles on my bike. I set the cruise control at 78 to 80 mph and rode on. the tach was right at 3000 rpm in 6th gear. she was real happy cruising at that speed.
Same here, 3000 rpm's seems to be the sweet spot for me as well. I rarely go above 4000, just no need to. Bike pulls hard and runs great with plenty of passing power when in 6th gear @3000 rpm's. Gas mileage is a solid 42 for me with this riding regime.
The following 2 users liked this post by Firebolter:
draper12 (10-12-2023), mjwebb (08-28-2017)
Old 08-28-2017, 09:01 AM
mjwebb's Avatar
mjwebb
think you're confusing optimal cruising rpms with optimal rate of transmission fluid transfer rpms
Ron517 (07-29-2019)
Old 08-28-2017, 09:03 AM
smitty901's Avatar
smitty901
You can run 60 in 6th all day long long as you not pulling a hard grade. lot will try to tell you different but they are wrong as can be.
The following 4 users liked this post by smitty901:
Another Old Timer (06-12-2019), mjwebb (08-28-2017), oldbie (08-28-2017), s-glide76 (06-12-2019)
Old 08-28-2017, 09:13 AM
mjwebb's Avatar
mjwebb
agreed, if in doubt refer to your owners manual which will confirm this under recommend shift points..60 in 6th is not lugging and is more rpms than I prefer for long stretches in 5th gear
Quick Reply: M8 optimal rpms at cruise
