Stage 3 worth it?
Old 09-06-2017, 05:47 PM
Bannana Boat's Avatar
Bannana Boat
Bannana Boat is offline
Sounds like the biggest question is whether you want to pay the dealer to install and keep the kit warrantied, or install yourself and not covered.
I have 4,000 miles on my stage 3 with 0 issues. Not sure how much you've read, but there are bolt in aftermarket cams for the M8 that will put out the same numbers as the EPA compliant SE stage 3 kit. And as DR BUICK stated, if your going to go SE, i.m.o. the stage 4 is worth it. The numbers I have seen have been in the mid 120's tq and hp.
Old 09-06-2017, 06:01 PM
Kyle Moore's Avatar
Kyle Moore
Kyle Moore is offline
Yes exactly. If I have the dealer do it now, my bikes warranty will cover it. If I do it myself later my warranty won't void but the vehicle warranty won't cover it. The M8 seems to be reliable, trying to decide what to do. Honestly I'd rather have the 117 kit from fuel moto with the woods cam but then I'd need to use a dynojet PV to tune it and poof your powertrain warranty is gone. It won't be a problem where I would be taking my bike normally, but if I'm on the road and have a problem and I go to the wrong dealer I might get caught.
Old 11-04-2018, 06:12 AM
TDH's Avatar
TDH
TDH is offline
Stage II
Default Stage 3 on 107
I have a '18 Breakout w/107. Just had Stage 3 installed using the Harley tune. First, everything works with no hesitation, flat spots or other hiccups. I have Harley Street Cannons installed and was disappointed with the sound. It didn't have any punch to it, kind of milk toast. With the compression bump to 11:1 the sound is much better, about where I want it. I won't anger the neighbors, but everyone will know it is a Harley. The new cam really makes itself known at idle. Love the new hit when each cylinder fires and the burble. As far as the power, it has more, but it is so seamless that it doesn't seem to be a dramatic improvement. It really feels like what it should have been to begin with new, not something you have to spend 5 grand for. I guess I was hoping for it to be able to make my heart beat faster, something that requires a seasoned rider and still has to be carefully controlled.
I have a ZX-14 with 200hp at the rear wheel and it does provide an adrenaline rush every time you max the throttle, feels like it is always on the edge of control. I didn't expect that kind of increase, but I was hoping for more than I received. Am I glad I did the upgrade, yes. Given what I know now I would still chose to do the Stage 3. From the hp/torque graphs it looked like Stage 4 requires high RPM for max performance. I choose Stage 3 because I don't normally run around at 4500 RPM. I wanted something that was useful the way I ride. I was hoping for the best of both worlds, good torque down low with a big kick at max throttle and RPM. Still, I am glad I did it.
If you are thinking of going Stage 3 you should know what to expect. You get a good increase that is very smooth and refined in use, just don't expect magic.
As far as cost I was quoted 16 hours for the installation($2000), parts ran $2411. The major plus is that I have a factory warranty on everything. If you go with a non-factory setup and blow the motor the extra for the labor you save will seem very insignificant compared to what you will spend to get going again. You may be down a couple HP with the factory setup, but it won't be noticeable/significant enough to justify the risk if you have problems. Plus you have to go with a tuner on a dyno since there is no standard tune. You have to hope the tuner will get it right the first time and you don't wind up with problems with hesitation, flat spots, or detonation. I can testify from experience that a inapt tuner can blow your engine by running it too lean and adding too much timing. If that happens you get a "Sorry about that, but we are not responsible."
With the factory system there is just no drama. It works from the first startup. I would prefer riding rather than running my bike around trying to get it tuned properly. Life is too short to have to put up with that kind of crap.
The following 8 users liked this post by TDH:
Buster (11-09-2019), DarkBrown (12-20-2021), Godinaz (03-22-2019), Jay_FLHXS (11-04-2018), mjwebb (11-04-2018), Newfie (11-05-2018), Rocketman83 (01-25-2024), skywheel (11-04-2018) and 3 others liked this post. (Show less...)
Old 11-05-2018, 01:40 PM
Rumblin's Avatar
Rumblin
Rumblin is offline
I got a new '18 RGU and had the Stage III kit installed almost immediately. I chose it over the IV because I like the cam profile better. I have only about 4500 miles on it now, but I can't complain. I would be curious to know how much more a real tune could impact the way it runs, but it runs out pretty good. I paired it with V&H crossover headers and Reinhart's with the cheap option hi-flo SE air cleaner. I would do it all again, and have kept my factory warranty.
Old 11-05-2018, 01:55 PM
teedoff65's Avatar
teedoff65
teedoff65 is offline
Received 1,474 Likes on 1,061 Posts
Wait. I'm confused. Are you saying you did NOT keep your factory warranty? Or you wouldn't do it all again so you COULD keep your factory warranty.
And if you did void your warranty, which with those headers you did.....why not get an aftermarket tuner instead. Sorry, like I said, I'm confused.
Old 11-05-2018, 03:00 PM
strych9's Avatar
strych9
strych9 is offline
Received 9,137 Likes on 3,508 Posts
I chose to look past the warranty for a few different reasons. As I see it, if I'm going to buy performance upgrades I don't want to be held back by EPA compliance. For those bike owners who live in states where they must be compliant, the SE stage kits are probably the best option. I personally feel that the quality of most aftermarket big-bore kits is better. For maximum performance aftermarket is the only way to go.
As far as "grunt vs top-end HP" goes, the cam and the exhaust system are the primary considerations. While my cam is aimed for higher-RPM power, it certainly isn't a slouch on the low end. I have the wrong exhaust system for torque; it begs for a good 2-into-1 setup. I may revisit that some day, but for now I love the sound and power of my setup.
It really comes down to your end goals and if you're willing to give up the factory powertrain warranty.
Old 11-19-2018, 04:14 PM
lifted's Avatar
lifted
lifted is offline
Do you have your Dyno sheet? I'm curious what your curves look like. We have similar builds. I'm running a 2-2 exhaust
system.
Old 11-19-2018, 04:43 PM
strych9's Avatar
strych9
strych9 is offline
system.
Sure. I have since ironed out the dip and seat-of the-pants HP went up also since this dyno run. I have a completely different intake on the bike; my original wasn't flowing enough. I need to get a new dyno run. Here's the original.
https://www.hdforums.com/forum/milwa...l#post17700181
Old 11-19-2018, 04:54 PM
Noisy Cricket's Avatar
Noisy Cricket
Noisy Cricket is offline
I love the stage III in my RKS. 5k trouble free miles since the upgrade and tons of power whenever I need it. I didn't go for the stage 4 as I didn't think the 10 hp was worth the extra $1k for parts. The sound with the MK 45s is great as well.
Old 11-19-2018, 05:12 PM
Heatwave's Avatar
Heatwave
Heatwave is offline
Member
Received 1,077 Likes on 638 Posts
Originally Posted by Kyle Moore
After talking to my dealer I'm gonna stay away from the dynojet and headers for another year and a half or so. Thinking about doing the stage 3 kit, the stage 4 kit seems like it's a more high rpm race setup. The stage 3 seems to be more grunt oriented. Is the 1500 bucks worth it? I have a month to go till my 60
Days are up so I was gonna call my dealer and and ask if I build the motor and buy the parts from them if they'll put it on my factory warranty or do their techs have to do it. If their techs have to do it I wanna buy the parts and have them install em later when it's shitty and wet outside.
I did both the Stage III and then later upgraded to Stage IV on a 117 M8. If money is irrelevant and you enjoy winding out to the mid 5000’s, you’ll enjoy the Stage IV. If you rarely shift above 4500 and “value” matters to you, stick with the Stage III. If you don’t wind out the throttle, my guess is that you’ll be disappointed in the Stage IV performance.
I had the SE Street Cannons. They are somewhat quiet but they do get louder with mileage. If the warranty matters, stick to the SE Street Tuner. If I had to do it over I would still do the Stage IV but that’s more about my riding style. If I shifted in the 4000 rpm range I would have felt somewhat cheated going from the Stage III to the Stage IV.
Super2k (10-30-2021)
Quick Reply: Stage 3 worth it?
