Question on Stage 2 or 3 for M8
Good to know! Can't wait till my warranty is up, or close to being up.
The aftermarket cams will probably more overlap and duration and I would imagine better sound. Combine that with a true optimized header and I bet it would sound more like a Harley should. Steve posted some pretty impressive numbers with the work he was doing.
I wouldn't waste my money going past a stage 1 through Harley. I personally would wait till after 1k miles and after the initial first check up to do performance mods. Im more into long lasting reliability to me these M8 engines are amazing even in stock form and not worth hot rodding and modiing. But to each there own. I think you should get your new bike ride it for a little first and then decide. I have a feeling youll be happy just doing a stage 1.
mjwebb (09-09-2017)
$1500..Dyno tuned SE Stage 1, runs incredibly well, heat not an issue and warranty intact..so good I've stopped there..what's not to like
it is important to get a reputable dyno tuner..you could start with the ECM Stage 1 calibration (in red) on the chart is what you can expect and you may very well be plenty satisfied, then take your time to find a competent tuner if you want more out it (in blue)
