Stock Air-Cleaner Hi-Flow Mod
Your original post about performing this modification last week left a lot to be desired, nobody including myself had any idea what you were talking about.
I give a man credit when credit is due, your video is the exact type of instructional video everyone cherishes because it's informative and you go through each step perfectly clear.
For anyone wanting to copy your modification this video leaves no doubt on the sequence, process and final product.
Two thumbs up for the video and for your ingenuity.
OS
OS
I would be proud to take credit for strych9,s excellent workmanship and class video,the breathing improvement is unquestionable!
However it is an alternative to my original thread which was a report on the more costly but excellent Screamin Eagle replacement filter and backplate!Obviously the intent was for you to buy the kit first.The photos do not show how large the replacement filter is! The standard filter can actually fit inside it! There is not a millimeter of unused space inside the metal cover to refit the Ram screen or lower cover.
There simply cant be a more efficient or larger filter under the M8 filter cover.
In order to retain the original look and Ram feature I cut away the internal protrusions and engineered a refit with fasteners,which anyone who has the kit and the will can do!
The tune I used was specific for my combo. Looking at this tune alongside the stock tune, a lot was changed, especially on the top end.
