Oil In The Throttle Body
The breather bolt and the tube in the first post.
I'm sure it does a great job, but not everyone wants to spend that kind of money for something minor like that. I would rather have it leak and wipe it up then spend over 1000 for something minor like that.
Having had a few different styles of filters and also converted to external, My observation is that not all systems do a good job at getting The vapors into the TB. Some are quite lousy at it and are just drippers. The Heavy Breather does a very good job of Getting the Vapors into the TB without making a mess.
A little while back I ran to Price, Utah and I had my intake puking oil. It recently had an oil change and they filled it all the way up to the full mark. It was bad enough it was on my exhaust, side cover, and bag.
Terrible
I can say it seemed to stop after I cleaned it all up and "adjusted" the level.
We were running pretty hard that day so I don't know if that contributed as well. 500 miles in 100 degree average temps. Whole lot of highway/freeway then short stops for gas/refreshment.
Terrible
Second, I don't know who told you a heavy breather kit costs over $1,000 but they lied to you.
Oldskewl (09-20-2017)
I tried to point that out but sometimes it's just not worth it.
I'm new to HD's but have some knowledge on engines. These are dry sump so most oil is kept in a remote cavity,not the crankcase like a wet sump engine. But some oil is in the case so the pump can circulate it. So the less room there is to absorb pressure pulses from the descending pistons, the more likely it is that pressure will look for a way out (the breathers). So, the higher oil level reduces that open space. I'm totally open to someone with more understanding of HD's to correct me if I am off the rails on this. Learning is a good thing.
Thanks.. Question... I assume the two ( crankcase and sump) are connected so wouldn't they both be areas with available space to absorb the pulses? If the level were higher in the sump, your still reducing that overall space,no?
stixvrad (09-20-2017)
