Anybody know how to..
Sorry you got nailed by the truck. That's ridiculous that some kid did that.
Most likely you bumped the kill switch with your hand at the light, its right next to the "start" switch and its easy to do. Once that is switched, you can't start the bike at all until you flick it back to the run position again.
While I haven't done it to mine, should be easy to take the module apart and simply de-activate the switch permanently in a few minutes. Good luck
TwiZted ... first I'm glad you're ok and that the bike only scuffed the crash bar.
The clutch interlock switch is part of the Left Hand Control Module (left switch pack) that is part of the Canbus wiring. I don't think you can disable the switch without affecting other functions such cruise control, gear indicator and possibly how the bike idles. IIRC some members had problems with stalling that was attributed to a bad clutch switch. I would have your dealer replace the switch pack so that your bike starts in gear and the other functions work as well.
As for those that never had a clutch interlock (safety) switch, it's been on all models since the 2007 models.
The following 2 users liked this post by 14GuineaPig:
mjwebb (09-19-2017),
TwiZted Biker (09-19-2017)
yeah, they know..but since they have replaced ours with the same thing and it's failing not sure they would issue a recall until they actually have a solution in place
Bypass that damned neutral safety switch on these things ? SOB got me bumped off my bike at a light today. It died for some reason, found I couldn't just clutch it and go so while I'm fumbling to find neutral a kid in a pickup bumped me trying to go around and of course he took off.
Discovered something about the RK, it's heavy. No damage I can find but a mark or two on the crash bar chrome low down underneath. Just pisses me off to no end about that switch it's got to go.
