What slipons for 2018 RGS and no tuner?
#151
From TAB:
It is possible to turn the tips in 90-degree increments. That being said with stretch bags if you turn the tip it will be several inches shorter than the end of your bag. If you're looking to bring them out to the end of your bags you would need a tip extension:
https://www.tabperformance.com/4-in-...-extension.htm
tabperformance (03-29-2018)
#152
From TAB:
#153
#154
#155
Well. I sold the Bassani DNTs, and I picked up those TABS on Ebay for $320. Chrome tips but, what the heck.They look ok.
Next step, take out the baffles and see what they look like. These have the 2.5" baffles and they perform as well or better than the stock mufflers. Sound is just a tad bit louder.
#156
#157
Seems to me, that's just the way the M8 motor is built. Mine is quiet at idle too. Haven't heard one that is loud.
#158
If they are too quiet did you try removing the tunable inserts from the Street Outlaw mufflers? There are three screws in the back of each muffler, the inserts can be removed/installed in less than a minute.
__________________
Jamie Long / Fuel Moto USA
The USA's Leader V-Twin EFI & Performance www.fuelmotousa.com
Contact 920-423-3309
Email jamie@fuelmotousa.com
#159
To me, they're all too quiet at idle. You really start to get better sound with a good cam/exhaust upgrade. Still even then they wont sound like any other harley engines.
#160
Idle was the biggest issue for me with the TAB muffs I had. The 2.5 baffles were very good at speed, but too quiet at idle. Replaced the cores with the Zombie "baffles" (it's literally straight pipe), too loud and not enough depth at idle. I should add that these observations were made after I had installed the Rinehart Slimline Duals header as I was trying to chase "the sound". The 2.5 baffles were dismally quiet with the stock header. The cat eats a lot of the sound, and there is hardly any tone from the left muff. Anyway, I now have the Rinehart 4.5" MotoPro muffs and have exactly what I wanted: deep tone at idle, and head-turning tone on the throttle. The baffles use no packing material that I can see, just perforations in the straight-through pipe. Everybody will have their own preference.
teedoff65 (06-04-2018)
