Transmission fluid transfer service bulletin
Old 10-18-2017, 05:28 PM
$tonecold's Avatar
$tonecold
$tonecold is offline
Received 1,741 Likes on 931 Posts
Originally Posted by TomcatCV62
Or, the fix is so expensive, they don’t want to fix it on their dime.....
Well basically they could convert a bike back to a cable actuated clutch for less than some of the things they have done!
TomcatCV62 (10-18-2017)
  #192
Old 10-20-2017, 04:05 PM
Spilot's Avatar
Spilot
Spilot is offline
Thumbs up
2017 Road King. I had to add approx 2 OZ immediately after the 1000 mile service at the dealer. It showed normal when checking with the bike upright, but low when resting on the jiffystand. Just returned from a 1500 mile trip through the Ozark's, and now due for the 5K oil change. Have been checking regularly due to this forum, and so far no loss of tranny fluid.
  #193
Old 10-20-2017, 04:59 PM
TomcatCV62's Avatar
TomcatCV62
TomcatCV62 is offline
Well, that’s good news. That’s the way it’s supposed to be.
  #194
Old 10-21-2017, 10:54 AM
BrandonSmith's Avatar
BrandonSmith
BrandonSmith is offline
Received 2,225 Likes on 1,409 Posts
Great to hear this. Are people taking their bikes to the dealer to get it on record? What is being said?
  #195
Old 10-23-2017, 05:42 AM
jcjetson's Avatar
jcjetson
jcjetson is offline
6th Gear
took my 2017 rk in to local dlr a couple weeks ago. been having tranny oil trasfer for 10k miles. put oil dye in tranny and found it in primary .moco says to adjust levels in both and ride for 1000 miles. will take it back this week. levels dropp
ed a couple ounces. they vowed to fix it . will let you know
  #196
Old 10-24-2017, 06:54 AM
2016CTRoadGlide's Avatar
2016CTRoadGlide
2016CTRoadGlide is offline
Originally Posted by mjwebb
long overdue, but at least they took the next 'official' step finally....must have exceeded a threshold for # of reported claims and the first step is communicating the monitoring process/procedure..sounds like maybe the seal/spacer instructions were a shot in the dark attempt..who knows
I have noticed the dropping fluid level on several occasions as well. Dealer added fluid once and then made official record of level when they finished the oil pump replacement for sumping issue. I am taking the bike in for the 1000 mile fluid check this week per the bulletin (it is down again when I checked it). I was curious about whether the lemon law might apply. Connecticut law covers motorcycles. Reasonable attempts is defined as 4 times within 24 months/24,000 miles or 2 attempts within 1 year if life threatening. I have not noticed sumping issue again although the new pump is very noisy especially on colder mornings with a high pitched squeal which is apparently "normal".
14,300 otherwise fun miles. I would love to keep this bike but might look at the 2019 models if they upgrade the engine to the 114.
Any thoughts would be appreciated. Cheers!
  #197
Old 10-24-2017, 02:10 PM
Beerbar's Avatar
Beerbar
Beerbar is offline
Originally Posted by Quik
Dealer told me today that they received a service bulletin about a week ago for the transmission fluid transfer issue. All the bulletin says for now is check/fill transmission to proper spec, ride for 1,000 miles and return bike. He said no official fix has been released though. Just wanted to pass this along for anyone who hasn't heard.
Service manager showed me the same thing last week. Its says fill and monitor
  #198
Old 10-24-2017, 10:07 PM
StevenL808's Avatar
StevenL808
StevenL808 is offline
Well now things are getting serious! After the dealer replaced a seal and a sleeve, I rode my bike for less than 200 miles and I’ve had to add in fluid. I extracted about 10 ounces of fluid from the primary! Then less than 50 miles later I had to add another six ounces to the trans. The bike is going to the dealer tomorrow.
Stay tuned!
  #199
Old 10-24-2017, 10:11 PM
sixguns's Avatar
sixguns
sixguns is offline
Received 1,458 Likes on 755 Posts
Stay tuned!
Sounds like your tech sucks at his job. sorry to hear about this, I would be totally bumed. I hope they get it right for you asap!
  #200
Old 10-24-2017, 10:21 PM
MotoJockey's Avatar
MotoJockey
MotoJockey is offline
Received 3,080 Likes on 1,262 Posts
What exactly is right at this point, lol! I just had my Tech drain an extra 8 Oz.'s laced with dye out of my primary today after 1700 mile. I guess that qulifies as more right that what StevenL808 just went through! He's right up there with Steve Cole!
Quick Reply: Transmission fluid transfer service bulletin
