Have run a several on the dyno and they act the same as the 2017's do, yes they transfer.
I doesn't look like there are any changes so it only make sense that the problem would persist.
Originally Posted by not a sock
On my '17 FLTRXS, yes.
According to the dealer; I'm imagining it............
Looks like you need to show them the service bulletin. Not that they have a fix for the problem, but at least you'll get them to recognize there's a problem.
Told me they had two bikes come in for this problem. They had put dye in the trans and neither one had any oil transfer to primary.
I asked him; 'then where is the oil going'?
Silence.
I said, 'mine sits on a concrete floor when it isn't being ridden; no oil there.' 'And if oil was leaking out, wouldn't there be oil all under the bottom of the bike'?
