I am challenged with the new bike.....
Received 14,656 Likes
This is the only possible relevant factor I can think of. My wife hits the scale at 112 so I barely notice her on the bike plus she knows not to be moving around. As far as the weight of the TP, don't get it. I have a detachable for the Road King and don't notice anything taking it off or putting it on. Perhaps it is just a mental thing OP has to overcome? Best of luck. Not going to write a book here on what should and should not be done with a passenger as I would usually give the average rider the benefit of the doubt regarding common sense.
You do understand the weight thing is mostly in your head, not that big a difference.
Two things to look at that will give you much better control a low speeds.
Extended rear brake pedal. It drops the angle gives you better control a low speed.
Adjustable clutch lever. It allows you to bring the engagement point in closer, again improving low speed control.
I ride a 2017 RGU and I am 1 inch shorter and lighter than you are.
The bikes more top heavy with the tour-pac. Esp 2up. I had trouble with the passenger floorboards or back seat riders boot hitting me in the calf's. I put on some passenger pegs and that solved that problem. I stopped using the front brake below 5 mph. I use the rear only to come to a complete stop. Made the stop more stable. That front brake by itself will dump you fast.
The thing that helped me the most was picking up the"Ride like a pro" video and practicing.
having 150ish lbs on top of the bike suddenly changes the center of gravity. Just keep riding with her, you'll get the hang of it. I always gotta pause for a sec and kinda re learn how to stop when my wife jumps on my bike, once you get used to riding solo all the time and you throw another adult on the bike your brain has to reset.
All the advice here is good. I have been riding with the wife for 38 years, she is six inches taller and a few pounds heavier (she doesn't read this, but why chance it?).
She "chair dances" going down the highway, but on the city streets I can barely tell she's there.
Practice makes perfect. I use the rear brake for the last few feet of a routine stop, and although it's been many years since I've had too, remind the passenger to pay attention.
If I lean, you lean. If I fall, you fall. We're in this together.
