Fueling oil pump
Fueling oil pump
Anyone bought one of these? Is there anyway to tell if my oil pump in my M8 is one that could fail? What exactly is failing in them? I was just doing some research on cams and stuff and ran into the fueling oil pump, I didn’t know there was an aftermarket upgrade for the pump. I’m surprised no one else has one, I’m guessing maybe it’s not happening as much as it seems, otherwise HD would be having them changed out under warranty instead of changing engines but who knows.
If you are speaking about the sumping issues, hd is on their 3rd version of the oil pump. Some early versions have not sumped. Some with the 3rd version have. So I would not be buying an after market pump in the hopes it will solve the issue. Because it might not. My guess is the actual number who are having problems is small. And until the root cause is determined I would not buy an after market pump just in case. But that's just me.
I have been looking at the 465 cam from SS. I’m not even gonna bother with SE parts. I just got my bike 3 months ago so I’m not in a hurry to void my warranty but probably after next riding season I’ll dig into it. Gonna do a pump while I’m in there.
Based on the information I have read the Aftermarket big bore kits MAY correct the issue. According to some experienced industry insiders, some of the Harley Stage 3 and 4 jugs were not perfectly round. This could contribute to blow by and excessive leakdown. When Fuel Moto tore down their first M8 they noticed a cylinder that showed signs of blow by due to rings not seated to the bore correctly. The aftermarket will correct the issues before Harley will I am afraid. The Fueling oil pump and Cam Plate is just the beginning. Although, I wouldn't bet it is the cure all for sumping in the M8.
Of oil in 4500 miles (knock on wood). I am also interested in doing a Fuel Moto 117 kit with the wm8777 cam. It has a big fat power band and is a prettt cost effective build. The 465 makes the torque of a bigger motor but lacks on horsepower.
Haha damnit now I really want that big bore kit.
Doshounds (11-19-2017)
It actually makes a lot of sense, you start foaming up the oil and the pump will not like it. It’s true for any motor. I ran mine hard on break In, I had to ride it 400 miles home. I took it easy for the first 50, pulled over, checked for leaks, let it cool off a bit. Then hauled *** home. My motor hasn’t burned a drop
Kyle Moore (11-19-2017)
