My Dealer’s Insight on MoCo Voiding Warranty
#141
after 2 years and just bought the addt'l 5 year ESP, since I plan on just keeping my bike and racking up a ton of miles..actually considering doing the SE Stage II just for the hell of it..but better ask a few questions to them cuz not sure adding that this late in the came doesn't come with some caveats compared to if I had done it in the first 60 days...sure don't want to spend more money to only get some half *** coverage
#142
If thats true, stage 2 aftermarket for you would be great. And you'd still be covered. Plus, you could have an S&S or Fueling oil pump and cam plate installed along with it.
#143
Actually I've read several sumping engines that were denied warranty repairs due to an after market tuner but they apparently did not experience engine failure. It would take some effort to find them. In both cases they went to a Feuling oil pump and plate as their solution out of their own pocket. One of them sent me several PMs about their situation
#144
Third party ESP? I was under the impression that at least discount ESP would not void warranty over aftermarket tuners and such. I might be wrong, but someone told me that after researching it.
#145
BUT, the labor is the same to return the bike to stock OR Stage II. So the only differential cost is the difference between the stock cam and the Stage II cam. Figure about $150 on the high side. Plus your deductible of $50. The ESP still gives you pretty good peace of mind and insurance should something really expensive fail.
mjwebb (08-10-2018)
#146
These are very different situations.
- VOID YOUR FACTORY DRIVETRAIN WARRANTY = YOU VOIDED YOUR ESP DRIVETRAIN WARRANTY. NO IF, ANDS OR BUTS.
- IF YOUR 2YR FACTORY WARRANTY IS INTACT AT EXPIRATION = YOU'LL HAVE FULL COVERAGE FROM ANY 3RD PARTY ESP EVEN IF YOU HAVE AN AFTERMARKET TUNER
- IF YOU DON'T KNOW IF YOUR FACTORY WARRANTY IS INTACT= CALL YOUR DEALER AND ASK THEM TO LOOK IT UP BEFORE YOU BUY A 3RD PARTY ESP WARRANTY
#147
Just to clarify (again). Discount ESP WILL provide coverage even if you use an aftermarket tuner (so long as they can't attribute the claim to the tuner like someone put the wrong map on the bike). BUT Discount ESP or and other 3rd Party ESP plan definitely WILL NOT provide coverage if you voided your factory warranty by using an aftermarket tuner during the factory 2yr warranty period.
- iF YOU DON'T KNOW IF YOUR FACTORY WARRANTY IS INTACT= CALL YOUR DEALER AND ASK THEM TO LOOK IT UP BEFORE YOU BUY A 3RD PARTY ESP WARRANTY
#148
well even the Harley sponsored ESP which i bought is technically a 3rd party one I guess...just need to read the fine print and ask them cuz I think even adding SE parts only covers replacement parts and not labor..I think...just need to find out of collateral damage as a result of failed parts would be covered..seems more complicated than it should be imo
mjwebb (08-10-2018)
#149
"Of course, with as terrible as my dealership is, they might have flagged it just because during one of my service appointments."
Yep, that's the concern, although they need a legitimate reason. A lot of guys could be at risk and won't find out till they make a warranty claim. Try calling a different dealer and ask the service guys if they could look up your VIN to see if your factory warranty is still intact. If it is intact, and retaining the warranty matters to you, then you need to take the necessary steps to ensure the bike is compliant during the factory warranty period whenever its at a dealership.
#150
I remember when HD dealers would ony sell aithorized HD parts. The aftermarket suppliers and independent shops was where the hot rodders went. HD went after the 'aftermarket' money with the expanded Screaming Eagle line. After market shops will resume picking up those customers again. Usually after the warranty has expired.
