Passing lamps and turn signal relocate on 17 rks?
Trying to confirm if I can add passing lamps and turn signal relocate to my 17 Road king special with a quick release windshield. Can anyone confirm?
I see some ebay specials out there for brackets that look similar to whats in the Parts catalog but the Harley site one doesnt come up as a fit for the 17 rks.
If it can be done can you confirm what is needed?
Thank you
Thank you
Mike Muery (09-12-2020)
Thank you
Thank you
What did you use here? Is it harley branded or aftermarket? Did you get or use a switch and is it plug and play?
I found this bracket and thought about going with eagle lights
https://m.ebay.com/itm/Auxiliary-Lig...k/282669850432
But only shows up to 16.
Aux Light kit
The kit is for a SG, SGS. will not fit RKS
This is the kit https://www.harley-davidson.com/stor...11-67800367--1
Go to boardtracker.com you can get it cheaper from them.
Install was plug and play, had mechanic do it and after watching him kicked myself in the butt, cause i could have saved 80 bucks doing it myself.
Doesn't the RKS already has passing lamps? i dont think there is a TS relocation kit.
Looks good!
Option1 - Ebay after market part, ordered from this seller at:
https://www.ebay.com/itm/4-5-LED-Aux...19.m1438.l2649
This kit comes complete with signal and passing lamps.
This kit is the least expensive route, fairly good quality, fit & finish are excellent for the price. However, let me caution you that these kit did not come with instructions and I had to do a lot or research to determine how to interface and connect the passing lamps and running/turn signals to the head lamp nacelle housing. It also did not come with toggle switches and I had to procure from local home depot electrical section. The main power source for the load is from the P&A accessories 20 amp power supply which I controlled from the toggle switch. I also recommend the'17 or '18 factory manual as reference.
Additional information can be found at CVOHarley:
https://www.cvoharley.com/smf/index....799#msg1394799
Option2: Get all genuine Harley-D parts. I suppose it will have all parts and hardware however, the down side is the overall costs. The passing lamp housing alone is about $500+ coupled with Daymaker lamps at another $500+
mikes300 (02-06-2018)
Anyone got an idea of how to wire these ? I am looking at this passing lamp kit but trying to figure out wiring before I pull the trigger. There is no Nacelle switch on the rks and the kit has bare ended wires only. Can I get connectors and plug them in somehow or how would I wire them? There are several videos and people that have done this but cant find anything on the wiring.
I have the passing lamps/indicators kit that I kept, off an 2014 SG
i want to relocate the indicators on my new 18 RKS and make this kit work. How do I do the wiring? I got nacelle switches, (I'm doing Fogs as well) And I'm also currently running the vented Windsplitter.. so I have to account for that. I can't figure out what to do with the wiring to the indicators, unless it's self contained with whatever I use for the passing lamps (like it is in the SG) Any advice , harnesses I need?
