M/8 valve seat failure.
Cam profile.. You fix the difference in valve stem clearances in cam profile. Not too hard..
While T-man has seen issues with the seats, my bet is that it was a manufacturing glitch.. Locals (dealers) probably get groups of bikes off the assemble lines.. His area likely got a shipment that had batch of motors with bad heads..
But how does cam profile have anything to do with the discussion at hand, specifically with the concerns of operating two valves with a single rocker arm?
Makes zero sense to me.
Received 5,373 Likes
Hope this makes sense.
Max,
Ok then. We're talking about two completely different things.
You're talking about shock loads imparted on the valve/valve seats based on cam profile.
The discussion I was involved in was in reference to a concern others had of one valve never fully seating because of the single rocker arm design.
The two are completely unrelated.
Thanks for the clarification.
Campy Roadie (01-01-2018)
Max,
Add:
What sets the lifter position will be the tightest valve..
I was wondering how long it would be before something like this came up with the 4-valve motors.
Even the Beemers provide for individually-adjustable valve clearances in their 4-valve twins by using variable thickness semi-spherical shims in the rocker tips. Did the MoCo actually believe that it could produce parts that were so accurate that they could bypass any kind of provision to match the clearances? Also, that all the individual parts would wear EXACTLY the same amount over time?
That's nuts - even for the MoCo - and that's sayin' a helluva LOT! Without being able to match the clearances, one valve will always open & close slightly before or after the other (depending on which one you're looking at), and that will cause a slight difference in the overall valve timing for each head as a result.
However, I can't really see how this could possibly cause any damage or excessive wear to the valve train components. All it does is affect performance.
I wonder what the specs are on this, how much difference would be too much?
