Stage II completed with Red Shift 468 Cam
The Red Shift Cam comes with a new bearing. Bought the S&S adjustable rods and gasket kit all from Zippers.
The following 2 users liked this post by jmyrick:
mjwebb (01-11-2018),
Oil, Gas & Leather (10-20-2020)
The following 10 users liked this post by jmyrick:
badcooky (07-17-2018),
FLshovelhead (06-29-2018),
HDRIDER2000 (02-21-2018),
Jay_FLHXS (01-13-2019),
Johnny Goodlife (01-15-2018),
and 5 others liked this post.
ok, just recall Steve Cole mentioning the stock valve springs come damn close to coil bind even with the SE TQ and PWR cams..probably a fine line in upgrading those cuz it was also mentioned too stiff of springs that are not necessary might cause other wear related issues so was just curious what folks were doing
lyork (01-14-2018)
Anyone ever get a price on valve spring cost and labor to replace?
No need to replace the stock springs for a properly sized bolt in camshaft. I would not want to go any bigger than 0.470 lift on a bolt in M8 camshaft. You have to be careful on too much lift as the production tolerances have to be handled. You also start running very close on piston to valve clearance in the OEM setup 107, 114 and 117 M8 engines.
The following 3 users liked this post by Steve Cole:
