Air Cleaners for larger builds
Here's a report with some good info on air cleaners.-
Differences Between Outlaw HiFlow Air Cleaner Systems
Dyno taken from the report-
__________________
Cristy
FREE SHIPPING - ORDERS OF $100 OR MORE - LOWER 48 STATES
www.DKCustom.com
Call: 662-252-8828
Text: 662-420-4891
Cristy
www.DKCustom.com
Call: 662-252-8828
Text: 662-420-4891
Is your indy running external breathers?
The S&S has that vortex directional thing that may help a little with the M8. The M8 manifold is offset to the right making the air horn close to the right edge of the filter, which makes for a tight right-hand turn for the air to flow.
I am considering both the SE Extreme and the S&S for now. Really not sure. The SE can be externally vented easier than the S&S from what I can tell.
I have been told by a few this flows better than the M8 Heavy Breather. Its one of the better ones available at this point for the M8.
https://www.harley-davidson.com/stor...ow-air-cleaner
These look interesting from T-Mann. Description says they can be used on different size builds and will be the last air cleaner you will need to by. I have no experience with it just sharing.
https://tmanperformance.com/product/...s-air-cleaner/
Nope.... I'm not sure what the material is but it sure is ok at engine temps... the breathers all bolted up just fine with the hardware provided by S&S..... I ran one on my '15 for 65,000 miles with absolutely no problems.... DW
