Added oil pressure gauge
The bracket was made from 10 gauge 1018 cold rolled with the cover made out of 16 gauge of the same.
The only fittings not made were from drag.
DS‑245250 SAE inverted flare male connector, 3/16” OD tube to male 1/8” NPT
and the line.
1204-8407 For 99-08 Twin Cam
The Oil line comes with a 1/4 pipe to 1/4 pipe and inverted flare adapter that is not used. You can go to Drag and punch the numbers in for pics. I was thinking I could bore the adapter out but doing so the inverted flare part would be too weak to use.
The barrel and bolt were made from 1 inch round and 3/4 hex 303 stainless.
Oil pressure is about the same as a good running TC.. Relief trips at 45 psi. 3000 rpm it ran about 40 psi and idle was about 15 PSI.. The was only a short 12 miles run with a couple stops and traffic and ambient temps in the 60s. It will likely drop when oil temps get hotter.
and the line.
Riverside Joe (02-14-2018)
The following 2 users liked this post by Max Headflow:
Johnny Goodlife (11-11-2018),
Sam D. (02-22-2018)
Very nice job on that fab! Too bad you had to do all that to get back what we already had on the info screen...my 15 actually read the oil pressure...my '17 M8 now just gives you an "OK"???? I bet there's a way to flash the ECM to give you back the oil pressure on the info screen..... anyone looked into this???? ...DW
