The Fix Is In!!!
  #221
Old 03-17-2018, 12:32 PM
Slyde's Avatar
Slyde
Slyde is offline
Thanks to You and Mark, lot of work and it's appreciated!
Brian
GPHDXLC (03-17-2018)
  #222
Old 03-17-2018, 12:40 PM
MotoJockey's Avatar
MotoJockey
MotoJockey is online now
Received 3,052 Likes on 1,255 Posts
Brian
  #223
Old 03-17-2018, 12:42 PM
$tonecold's Avatar
$tonecold
$tonecold is offline
Received 1,729 Likes on 926 Posts
Originally Posted by Steve Cole
Well here we are, day three of testing, tuning and riding. I think I'm finally wearing Mark ($tonecold) out with changing cams and being a test pilot. We should wrap up all the testing today and tomorrow Mark gets to take his 11 hour drive back home. He will be reporting the results once he gets home and a little time to get caught up.
Hey, you forgot to tell them that the transmission hasn’t transferred or leaked a drop, which is more than I can say for the pushrod tubes.
So the fix that I started this thread for seems to be working fine. When I do the last cam install I will pull the cover and the slave cylinder off for a look 👀, but I expect everything to be good.
The following 24 users liked this post by $tonecold:
2013superglideseattle (03-17-2018), Bigiron (03-20-2018), Cbyway (03-19-2018), cookiemech (03-17-2018), CR3999 (03-20-2018), FM500 (03-17-2018), G'day (03-18-2018), GPHDXLC (03-17-2018), hattitude (03-21-2018), jerbear4196 (06-25-2018), Johnny Goodlife (03-18-2018), johnnynitro (03-18-2018), lortsie (03-17-2018), madmat (03-17-2018), Max Headflow (03-17-2018), MotoJockey (03-17-2018), Northernproducer (03-18-2018), Slyde (03-17-2018), stixvrad (03-19-2018), SWMB (03-17-2018), tonyd2017 (06-08-2018), twosailin (03-17-2018), undy (03-17-2018), VDeuce (03-17-2018) and 19 others liked this post. (Show less...)
  #224
Old 03-17-2018, 01:32 PM
borrec's Avatar
borrec
borrec is offline
He was being nice as he didn't want to steal your thunder.
  #225
Old 03-17-2018, 02:36 PM
HDs4me's Avatar
HDs4me
HDs4me is offline
Originally Posted by 103Eagle
Kinda seems as PROOF IT DON'T WORK! Guess they might have thought it was the fix, found out it was not, forgot to remove it where it was and now is covering their asses........
Eagle Out
https://serviceinfo.harley-davidson....ocument/417967
The following 3 users liked this post by HDs4me:
G'day (03-18-2018), OzBobPanGlide (03-18-2018), swmnkdinthervr (01-04-2019)
  #226
Old 03-17-2018, 08:57 PM
$tonecold's Avatar
$tonecold
Default Inspected Seal
So when we were doing the last cam install today, we (Steve Cole and I) pulled the actuator (slave cylinder) for the clutch to see what I have going on with the nut and seal fix for transmission oil transfer. What we saw was exactly what I had hoped we would see.
The little bit of oil you see in the top picture is condensation from the primary case. I use Redline transmission oil so if the seal was leaking it would be pink oil there. I really hoped this would take place to lubricate the clutch pushrod and the plunger on the actuator. We did add an O-ring to the actuator to keep oil from leaking from the cavity.
The following 15 users liked this post by $tonecold:
2013superglideseattle (03-17-2018), Cowboy Rob (03-18-2018), FM500 (03-18-2018), G'day (03-18-2018), GPHDXLC (03-17-2018), Johnny Goodlife (03-18-2018), johnnynitro (03-18-2018), madmat (03-20-2018), mjwebb (03-17-2018), MotoJockey (03-17-2018), Northernproducer (03-18-2018), OzBobPanGlide (03-18-2018), SWMB (03-18-2018), twosailin (03-18-2018), undy (03-17-2018) and 10 others liked this post. (Show less...)
  #227
Old 03-17-2018, 09:50 PM
blacktop37's Avatar
blacktop37
blacktop37 is offline
All of us thank you very much!! Is your fix and Harleys "mystery" plastic seal fix related? Do you think theirs is going to work?
  #228
Old 03-17-2018, 09:58 PM
$tonecold's Avatar
$tonecold
Other than the location in the transmission, no they are not related. I have no idea if their disc is going to work. I think it might on a transmission that is transferring a small amount. For the ones pushing several ounces across in a few hundred miles, I guess we’ll have to see.
  #229
Old 03-17-2018, 10:13 PM
MotoJockey's Avatar
MotoJockey
Do you think that condensation is of any concern? I know it will flash off as the bike reaches operation temp, but I guess it looks like more than I would have expected. Of course I'm not all that bright, soooooo. Maybe it's from all that SoCal rain lately, lol......
  #230
Old 03-17-2018, 10:18 PM
badcooky's Avatar
badcooky
badcooky is offline
Awesome !
Quick Reply: The Fix Is In!!!
