Oil light comes on when stopped.
Recently finished my Stage ll, been riding without any issues.....until now.
The oil light comes on after about ten seconds when fully stopped, then goes away as soon as l blip it, keep revs above 1k, or take off.
This is the second time this scenario has hapened. l did pour a quart of oil to replenish some of what was wasted when l did the Stage ll. No check engine light, no oil leaks (been leeping my eyes on it), no weird knocks, etc.
Any thoughts?
Any thoughts?
Did you perform the pump alignment procedure when you did the cam? Did you look at the pump manufacture date wheel to note the date?
You can also perform the M1450 sumping procedure and see how much oil is drained when you pull the crank sensor.
Or you can take it to the dealer and let them do what they do. And wait.
Either the switch is fubar or the oil pump is fubar. When my oil pump went south the light never came on. It started coming on two weeks or so ago. I went and bought another china oil pressure switch and installed it and also checked the oil pressure for the 50th time. All was fine. Just a junk HD part...
It was over filled to be honest, not by much but nonetheless. Pulled plug & will double check tomorrow.
This is exactly what l didn’t want to read. Lol. Hope you are not right in this case!
Oil pump was not removed nor tampered when l did the cam swap. Neither l touched the gerotor, manual did specify to not move them as it could lead to malfunction. Not sure what you mean by correctly aligning it, can you elaborate?
l was not aware of M1450 bulletin, just Googled it & is a place to start. Will try the procedure tonrrow to see how many ounces it pukes out. I have not experienced any power loss at all.
Same here, been a couple weekds since l did the cam swap and just yesterday & today the light came on. Like l said in the reply above, l have not experienced any power loss at all.
So did you replace the oil pressure switch? Or the oil pump?
How did you find out your pump went south?
If you remove the cam plate, you need to allow the pump to find its natural center when you are tightening the 4 pump screws to the cam plate. The m1450 procedure contains an updated alignment process. You leave the pump screws loose and rotate the engine 360 degrees then tighten the pump screws.
[QUOTE=TAKITO SEXY;17175165]
If you pulled cam plate and left oil pump in cam chest you have to realign the pump. when you bolt the cam plate back on there is a process to align it. There is a sequence to tighten bolts then rotate motor 360 degrees then tq down.
9 times out of 10 whatever goes wrong when you just replaced something on your bike or fixed something is directly related to what you touched. Its kinda rare to have someone change the oil and "wow changed the oil today, and all of a sudden my bike wont start" and its not related to something he did while changing the oil (whether its bumping into something, knocking a wire loose ect.) so backtrack what you did and what you touched last time you worked on it.
username not valid (03-26-2018)
I am taking it apart to re-align oil pump today, hope to finish it up tomorrow. Will check for sumping after re-assembly as it seems overkill now. I am not losing any power in any gear.
[QUOTE=pittz5;17175339]
True, I just find it weird it took almost two weeks for the light to lit up. It is what it is now and will come apart after checking for sumping.
