Steve Cole's & $tonecold's Cam Testing
Old 07-19-2018, 12:09 PM
$tonecold's Avatar
$tonecold
$tonecold is online now
Received 1,731 Likes on 927 Posts
Originally Posted by yobtaf103
Stock mufflers then ?
I used the stock muffler cans with Fullsac 2" cores installed.
yobtaf103 (07-19-2018)
  #162
Old 07-21-2018, 09:36 AM
jpbo's Avatar
jpbo
jpbo is offline
How does it sound with theses cores ?
Is it an easy replacement task to swap with fullsac core
thanks
  #163
Old 07-21-2018, 12:17 PM
$tonecold's Avatar
$tonecold
thanks
I wasn’t really happy with the sound. Fullsac offers what they call techmat for the CVO mufflers, you might check with them to see if the Techmats will work with the stock cans. I think that would make them sound much better. They weren’t hard to install, Fullsac has a step by step instructions with pictures showing how to install them. The power they made with the stock header without the cat was as good or better than any other system I have seen posted and the cost is much less.
  #164
Old 10-20-2018, 10:43 AM
$tonecold's Avatar
$tonecold
Bump to the top
  #165
Old 10-21-2018, 09:57 AM
rideon's Avatar
rideon
rideon is offline
Thank you guys for all the great info in this thread!
  #166
Old 10-21-2018, 11:51 AM
Cazador's Avatar
Cazador
Cazador is offline
Member
Received 3,323 Likes on 1,853 Posts
Did I miss what tuner you used for this testing?
I have been contemplating a cam change on my M8 107. Looking at the graphs I would be pleased with the TTS 100. I have enjoyed the quiet factory pipes. Would I be giving up much by keeping the factory exhaust with this cam?
I guess the question is if I change the cam and add the tuner am I going to get reasonable results for the money?
  #167
Old 10-21-2018, 12:34 PM
$tonecold's Avatar
$tonecold
The TTS MasterTune was used for tuning.
You would lose some with the stock exhaust, but probably not as much as you think. The TTS 100 was very impressive at low rpm. If you’re looking to keep the pulling from idle up like the stock cam then it is what you want. It just makes much more power than the stock cam.
dcfatboy (10-27-2018)
  #168
Old 10-21-2018, 12:35 PM
IdahoHacker's Avatar
IdahoHacker
IdahoHacker is online now
Received 2,953 Likes on 1,685 Posts
Originally Posted by $tonecold
Bump to the top
I cannot believe I somehow missed this thread when it started back in March. Double thanks to both you and Steve for all the great work. I have to shake my head when I think about the fact that there is no button on the motor that you push and the cams squirt out onto the floor, ready for the next set to go in. I am in awe.
Thanks again for sharing your time with the group.
  #169
Old 10-21-2018, 04:45 PM
Cazador's Avatar
Cazador
Cazador is offline
Member
THANKS. I have a limited so I am just looking for a little better than stock and don't need it to be a drag bike.
Thanks again, I appreciate your help and the work y'all put into this.
Bayou FLHR-M8-128" (11-15-2021)
  #170
Old 10-27-2018, 04:07 PM
dcfatboy's Avatar
dcfatboy
dcfatboy is offline
I would be interested in what you decide. I'm thinking along the same as you.
Quick Reply: Steve Cole's & $tonecold's Cam Testing
