M8 Cam Bearings
#82
Doesn't matter. You kneel on the ground beside the bike with bike running on the jiffy stand.The 24 inches is to get you away from exhaust noise and to the side of the bike - not straight up. Use the hand and ear of your choosing. Personally, I don't work on the engine while sitting on the bike.
#83
Sorry to hit an old thread but wanted to see if anyone has heard this on an M8 from the cam chest area. I have a 2020 Road King with a 107 that I bought 3 months ago. Ever since new, when the bike gets warmed up, there is a buzzing sound that sounds like it is coming from the cam chest area. I only hear the noise when still at a red light or at idle. If I let the bike start to pull, the buzzing "seems" to stop. I took the bike in today for the 1K mike service and asked the tech to look at it. After a few hours and a long test ride, they came back with the answer that they had never heard this before and wants to contact Harley. Said the bike ran strong, and no metal flakes in the fluids. Here is a link to the video of the buzzing sound.
#84
From the OP
For those of you upgrading your cams in the M8 spend a little extra and replace the stock cam bearing.
Pic left is SE and right is stock one taken out after 11k miles.
Also, be aware a lot of the M8's are having issues with the plastic lifter plate that holds the lifters in place. They're cracking and allowing the lifters to spin, thus damaging the cam.
Never heard of the lifter cuffs shitting themselves and destroying motors IRL ?
#85
Just did Stage II with Power Cam on my 2020 RG Limited. Replaced the bearing with SE Bearing and also installed S&S Lifter Cuffs..Cheap insurance on upgrading the parts!
And, oh the factory is putting way too much Loctite on the bolt that hold the Lifter Cuffs on and the dam thing breaks, then you have to use a heat gun and heat the area from inside the Cam Chest to remove the broken stud. S&S has a Utube video on the procedure. Oh, its tuned using SE tuner..
#86
edit: never mind realized question was OT thread hijack, sorry
#87
If you think about it, replacing the lifter cuffs has proven to be more problematic than the cuffs themselves.Where are the failures of the OEM cuffs? In my opinion, changing out the lifter cuffs is one of those feel good things for folks that feel better not having plastic parts in their engine. Not that this forum is the gospel, but changing out the M8 cam bearing has also shown to be more problematic than the bearing itself. Old wives tales, remember to never set your battery on the concrete.
#88
If you think about it, replacing the lifter cuffs has proven to be more problematic than the cuffs themselves.Where are the failures of the OEM cuffs? In my opinion, changing out the lifter cuffs is one of those feel good things for folks that feel better not having plastic parts in their engine. Not that this forum in the gospel, but changing out the M8 cam bearing has also shown to be more problematic than the bearing itself. Old wives tales, remember to never set your battery on the concrete.
It's a solution to a non problem. I have not heard about a lifter cuff failure and I'm on these forums every day, but I often hear about broken lifter cuff bolts, I left mine alone.
I did change the cam bearing but I'm not hearing about their failure either. AND I'm not hearing about anybody being thrown out of a dealer because they have an aftermarket tuner, despite all the hand wringing that goes on about it here.
I'm done.
#89
Indeed.
I'm done.
I'm done.
Agreed. There are numerous one-offs, or 'it happened to me' and it means every single bike made by harley is experiencing this failure. I am in the midst of making decisions on a cam upgrade myself and have encountered numerous suggestions.... Some excellent and some downright overexaggerated.
For the lifter cuffs suggesting to be upgraded, I have only heard about issues with breaking the actual Cuff bolts trying to replace them. Other than the stock ones being plastic and psychologically that must equate to being cheap and must mean they'll fail, is there numerous circumstances with them actually failing on M8s? Perhaps in a monster big bore build with higher than normal power than what was engineered to handle, but in general, are people stating these are somehow failing on a regular basis and therefore are room for concern? Sure I'll replace mine with the S&S ones if I buy a kit that includes them, I mean why not and I'll replace them if I install non-HD parts when I'm out of warranty. But I'm hearing stories saying "you better replace yours or else you'll be sorry".....what is the basis of these comments.
#90
