What are you guys with PV, TTS or any tuner for that matter seeing for the cruising range AFR, canned map or dyno tuned. Just curious if there is a big differenc in what people are running in the M8. Thanks.
Above 3500 most are happy between 13.9 to 14.2 below 3500 the boys around here are a little secretive.
Heard a couple of people say set the closed loop cruise range to 14.0, that seems pretty rich for that range but I'm far from an expert so that's why I wanted to see settings from multiple tuners to see where they are.
14.0 would likely exceed the useful range of the narrow bands (roughly 14.2 to 15.0). Likely outside the range for closed loop (assuming narrow bands).
