What is up with the plug wires under the tank
Spark plug wires
Did you take the tank off, or at least brace it up? I read some where that it takes a special tool.... Do not know that to be true.... Good luck. CSM-H
Gotcha, yeah that may well be a special tool. But I'm sure someone's found a shadetree solution. Edit: Found this from $tonecold on another post:
"To change the inside plugs you will have to pull the fuel tank, which isn't a big deal. You will also need a plug wire puller to get the inside plug wires off without damage to the wires. They about $10-15. If you want to do it, it's not that difficult"
Just put a set or orange wires on mine. Took twice as long as on a twin cam.
Did not lift/remove the tank I have a spring steel plug remover from the 60's. I did have to bend the boot as it came up to not rub the tank. 17 RGS.
Hint: Twist the boot first as it typically is stuck to the plug. Twisting breaks it loose then much easier to lift off of the plug. I have seen some stuck so tight that some rubber was left on the plug. They get very hot which causes that.
I just replaced my plug wires last week. I did remove the tank, but I did not need a special tool to remove the wires from the head, I just used needle nose pliers to pull up on the boot, not wire. They came off without any issues. What was a little trickier for me was installing the new wires on the coil side. I did not feel the "click" to let me know that the wires connected to the coil, even if pushed all the way. I did feel the "click" on the spark plug side (all four) and the bike runs fine, and no codes, so I assume they are installed correctly.
