Fueling oil pump installed and ride report
It is just amazing if you look to the past when HD comes out with a new engine...there is always an issue with it....On the EVO I think it was base gaskets and Rocker Boxes always leaking....The twin cam..well we all know about the crappy cam bearings, Crankshaft after 2002...left side bearing and cam shoe issues...Now with the M8 it's an oil sumping issue
I would think he is past the point of Harley having responsibility to fix the issue since he went with aftermarket parts....Not an excuse as it still shouldn't be happening.
Very interesting on the mods. With the vent line pulling a vacuum, I wonder if it's helping with the sumping issue. I suspect that it is. If you can lower the pressure in the crankcase significantly, you lower the pressure variations in the crankcase. Based on the historic TC development issues, I suspect that this could help with the sumping.
You breather system seems close to what SnS uses on their crate 124s. Wonder if they are onto something.
Do you have any idle issues? Drawing crankcase air directly into the manifold without a PCV valve seems like it would cause the return to idle to be a little erratic. It would be if carbed but maybe the EFI conpensates?
While the fueling pump should help due to better scavenging, I suspect that the advantages decrease at the pump wears in and the gerotor side clearance increases. Still the venting idea may be the answer. It might be interesting to disconnect the vent line from the manifold and leave to open air to see if its the pump or the venting that is helping.
Very good work. It's nice to see someone taking the challenge and working to fix the issue instead of complain about it.
An interesting not on the crank runout.. On TCs the flat for the gear is in line with the crank pin. If it's the same on M8s, the crank is spreading not twisting. I've seen this issue on TC cranks, mainly early SnS stroker cranks with the smaller crank pin. While the M8 has a larger crank pin, I wonder if it''s doing the same thing. On the early SnS cranks, the flywheel / crank pin flex on the inside near the rods. Might be an opportunity for SnS to make a stronger one.
