Fan assisted oil cooler question
Old 06-18-2018, 06:44 PM
Nismogsxr's Avatar
Nismogsxr
Nismogsxr is offline
After installing the kit I can verify just the fan shroud will not fit the oem oil cooler on my 17 SGS. The mounting brackets that hold the OEM cooler in place are welded onto the sides and top of the cooler. The fan kit doesn't have any brackets welded onto the cooler, there are tabs on the sides and top of the shroud that hold it in place. The only way that I see it MIGHT fit is to take a Dremel and cut off the 3 metal brackets and clean them up
Markd12c
Oil Archive (no new posts)
07-10-2019 07:41 PM
bladesmith
11-26-2008 12:30 PM
maintainin
Screamin Eagle CVO Models
17
05-15-2008 08:43 PM
rideon
05-15-2008 02:48 PM
redhwk44
07-25-2006 02:40 PM
Quick Reply: Fan assisted oil cooler question
