Holy S*** my new 2018 Lowrider is making a loud noise
Old 06-16-2018, 07:57 PM
P51Driver's Avatar
P51Driver
P51Driver is offline
Default Holy S*** my new 2018 Lowrider is making a loud noise
I have a new 2018 Lowrider with just 107 miles on it.
Today was the first time I took it over 3000 rpm and at about 3000 rpm it starts making a rather loud rapping noise. Not the typical ticking but more of a rap rap rap. And it just gets louder the higher the rpm. I have only took it to 3500 rpm as it is still with in the 500 mile break in period. I am almost afraid to ride it as I don't want something letting loose in the engine.
I live about 60 miles from the dealer so I will have to wait until Monday to take it in. I just hope it is OK to ride it to the dealer.
Old 06-16-2018, 08:07 PM
purpledeuce's Avatar
purpledeuce
purpledeuce is offline
I have no idea if it's this or not, but check the motor mounts. It's not uncommon for techs to not tighten bolts
Old 06-16-2018, 08:08 PM
teedoff65's Avatar
teedoff65
teedoff65 is offline
Received 1,474 Likes on 1,061 Posts
Did you get a service plan with the bike purchase? Mine has free pickup or delivery. Also your hog membership may have road side service and might haul your bike to the dealership.
Old 06-16-2018, 08:52 PM
Flstcjay's Avatar
Flstcjay
Flstcjay is offline
Ride it like you stole it... straight to your dealer. It’s on warrantee. Have them lake a listen.
PFWiz (07-18-2018)
Old 06-16-2018, 09:21 PM
jclax01's Avatar
jclax01
jclax01 is offline
I would probably have the dealer pick it up if you are concerned with the noise. it would be a warranty item if something is wrong and why risk further damage. I bet its a free pick up for something like that.
The following 2 users liked this post by jclax01:
anthony_b. (07-17-2018), PFWiz (07-18-2018)
Old 06-16-2018, 09:23 PM
P51Driver's Avatar
P51Driver
I wish the dealer had pick up but they don't. Anyway it is my responsibility to get the bike to them.
Also I just went out and started her up to see if I could hear anything at idle.
What I hear is a inconsistent tapping/ticking sound which almost seems to be coming from the primary. Maybe a loose primary chain or a loose compensator?
Old 06-18-2018, 12:15 AM
sto's Avatar
sto
sto is offline
6th Gear
Primary chain adjuster needs to jump up a notch. Without over-revving the engine, do a couple of quick upshifts, and the chain adjuster will do what it's supposed to do.
Old 06-18-2018, 07:34 AM
RK12's Avatar
RK12
RK12 is offline
Thats most likely the issue. Mine over tightened and was whining like a supercharge. Some do not adjust at all. Should be checked on a 1000 miles service though.
Old 06-18-2018, 07:09 PM
P51Driver's Avatar
P51Driver
sto
Could you please be more specific on how to perform the "quick upshifts" to get the primary chain adjuster to tighten up?
I don't quite understand what you are saying.
Thanks
Old 06-18-2018, 07:16 PM
PA1195's Avatar
PA1195
PA1195 is offline
Can't verify this but elsewhere here it was suggested to warm up the engine/primary chain. Shut down and put in gear. Roll the bike back and forward against the transmission a few times. Idea was to put some slack in the primary chain enough for the adjuster to take up slack. Has to be a warmed engine not cold. All I read.
If still loud could be engine problems. If so don't do whatever makes it loud until the dealer has a look.
Quick Reply: Holy S*** my new 2018 Lowrider is making a loud noise
