Here is a transmission problem coming I bet
here is my gear set. No warning just grinding local dealer has done6 already. turns out not hardened all the way causing problem. My father took to work and had it checked. https://cimg7.ibsrv.net/gimg/www.hdf...0cafc205e.jpeg https://cimg8.ibsrv.net/gimg/www.hdf...de139fc5c.jpeg |
Problem coming? I'd say it already arrived. Hopefully the repair will be covered.
Originally Posted by hey man
(Post 17505979)
problem coming? I'd say it already arrived. Hopefully the repair will be covered.
Wonder what the Rockwell is supposed to be and what it measured at...
Originally Posted by VDeuce
(Post 17506042)
(Post 17506042)
Second one I've seen reported here in about two years. The last one was due to insufficient hardening.
Originally Posted by GTK
(Post 17506195)
I would also like to see test results from a certified metallurgist. Just stating trans has improper hardened gears caused trans failure and OP's dad said so,where is the proof? Maybe improper shifting is at fault.At this point who knows.Hope OP has better luck with his Baker trans.
(Post 17506195)
and if I get called full of shit oh well. you can tell by looking not a miss shift be more than a couple teeth. I have blown up a lit of shit racing over the years |
(Post 17506042)
© 2024 MH Sub I, LLC dba Internet Brands
