Engine oil change proceedure.
BrandonSmith (07-19-2018)
If you search through the M8 section in here thers an illustration right outta the service manual that shows the proper plug that someone posted up.
Order up a service manual. Boardtracker sells em. Your owners manual may show the correct one for engine oil.
To make the job easier HD sells a proper oil drain pan to slip under the filter to prevent oil from getting all over the motor when you take it off.
Also going to need the correct cap style filter wrench which they also sell.
psyshack (07-21-2018)
https://serviceinfo.harley-davidson.com/sip/content/document/view?id=1127092882539021331¶meters=highlight%3 D2018+touring%26openProcedure%3D387696#479006!!9!5 767
Is it so surprising that the owners manual (link shown above) might show such vital information as the procedure for changing engine oil, primary lubricant and transmission lubricant?
The subject is detailed in the Owners Manual that came with the bike, the online version available from H-D, or the numerous YouTube videos.
Did you not refer to the service manual to change out the cam?
The following 2 users liked this post by Cold Forged:
BrandonSmith (07-19-2018),
TTS Performance (07-19-2018)
https://serviceinfo.harley-davidson....479006!!9!5767
Thanks for getting me the info so quickly.
funny thing is, I was told long ago by a very experienced and knowledgeable HD service manager, and he was joking and exaggerating of course, but he said truth is if it had a quart of oil in them it would be enough to provide lubrication by design..but I agree with you..don't need to get it Full, unless you want to oil your AF..only benefit is more oil = less oil temp in theory..but these hold more oil than their predecessors
