Transmission fluid transfer with a twist. Help?
I'm gonna try to make this short as I'm sitying in a hotel room on my tablet. Heading to Sturgis and I am having transmission fluid migrating to the engine case. Primary fluid level is bang on but my crank case is gaining fluid while the gear box is losing it. Stopped st a dealer 2 hours out of town and lost about 10 oz. They called tech support who advised them to correct fluid levels and put dye in it and have me stop at the next dealer and have them check it again. I'm sitting in Great Falls, Mt waiting for the dealer to open and see what they say. Anybody have any ideas or experience trans fluid migrating to the engine oil. I may need to make a decision here soon on whether to continue or head back home. Thoughts.?
Update.... Well the dealer in Great Falls wasn't much help, kinda piissed me off actually. They knew we were coming the day before with dye in the transmission and they didn't have a black light and claimed that they couldn't get one once we got there. Anyway that's another story. The bike as suspected, lost another 8 oz this time with the engine oil level gaining fluid so I decide to cut my loses and head home before I got too far. We again confirmed that the primary oil level is bang on. I didn't want to spend hours every day at a Harley dealer having the correct the fluid levels every day, and we all know how busy Rapid City Harley is during rally So we corrected the levels and limped it 5 hours home. Gonna regroup, drop it off at the dealer on Tuesday and head to Vegas. Reading the forums, I never came across a migration for trans to crankcase so I will keep ya'll up to dated when I here from the dealer probably later in the week.
For transmission oil to be transferring to the engine oil there would have to be a leak from the transmission to the oil reservoir under the transmission. I would suggest having the dealer pull the reservoir (engine oil tank) to see if there is a visible leak. Sounds like you will need a transmission replacement. The only other way would be through the primary which would see a level variation of some degree, either more or less fluid.
Just a typical H-D dealer. They can't help themselves. If they weren't totally clueless hacks and BS artists, they'd be in a different, less bottom-feeding line of work.
