Seafoam Question?
Old 08-12-2018, 09:45 PM
Glock-45's Avatar
Glock-45
Glock-45 is offline
Default Seafoam Question?
Just out of curiosity, are any of you guys using Seafoam on your Milwaukee Eight?
Seafoam has been proven to de-carbon engines pretty well and I was considering using it on my 2017 SGS.
Just curious if it indeed has worked well for anyone using it on their Milwaukee Eight motor.
Thanks
Old 08-13-2018, 03:59 AM
Kenney's Avatar
Kenney
Kenney is offline
Do you need it? What do your plugs look like? Yes it works and I have used it as preventive maintenance (following the instructions). If you motor is using a proper tune them adding Seafoam just before when you do an oil change should be enough.
KenK
Old 08-13-2018, 08:55 AM
TriGeezer's Avatar
TriGeezer
TriGeezer is offline
Received 29,273 Likes on 11,143 Posts
IMHO...Seafoam is great as a fuel stabilizer. But, if you are looking for an additive to clean the inside of your motor, then I’d get an additive like Shell Techron that is specifically designed for that purpose.
Old 08-13-2018, 09:22 AM
PDB17UltraRG's Avatar
PDB17UltraRG
PDB17UltraRG is offline
Techron is what i use i try to buy it in my gasoline when i can plus ill add it a couple time s a year.
Old 08-14-2018, 06:23 PM
FurryOne's Avatar
FurryOne
FurryOne is offline
Rather than worry about the gunk from the breather bolts screwing up my M8, I switched over to a catch can. It's still inside the breather housing, but as soon as the warranty runs out I'll be changing it over to breathe outside. I switched back to the normal system just before my 5K service, and a few hundred mile later when I went to change back to the catch can the intake had oil in it where it didn't while the catch can was connected.
giacomo56
12-09-2018 10:12 PM
fxdx1985
11-12-2018 03:28 PM
fatbob_jay
08-29-2018 08:59 PM
Larry64
EVO
08-26-2018 06:58 PM
LunaticFringe
04-12-2015 01:45 PM
Quick Reply: Seafoam Question?
