114 in the Ultra Limited & RGU?
Midnight Z71 (08-16-2018)
jd05flhtci (08-16-2018)
pretty fair assessment..I rode the 114 heritage and my 107 SE dyno tuned Stage 1 ran better and stronger imo for about the same $1300...of course folks will spend the same on modifying the 114 and that would change...but if money was tight I'd rather spend it on getting the engine to breathe better and run more efficiently with a proper tune than have a bigger stock engine
The following 2 users liked this post by mjwebb:
Heritage07 (08-19-2018),
olehemlock (08-16-2018)
olehemlock (08-19-2018)
More stroke. 4.374 vs. 4.5" stroke.
As to if its physically a "beefier" crank, that I dont know. I doubt it because it still has to fit in the same case and I believe it uses the same bearings from 107 to 114.
I mentioned it to the dealer and he said since the CVO weighs 30 lbs. more than the standard Limited, it doesn't make much difference. I did notice it put out more heat than my bike at slow speeds and of course when stopped.
