Oil consumption
oil consumption
I've had many motorcycles over the years... the first one bought used and all the rest bought new.... my current Harley is my 5th Harley i've owned...none have used any noticeable amount of oil between oil changes... I do all service on my own bikes and change oil every 5K miles... I bought my current 2018 fat bob 114 without hesitation... used a little oil up to the 1K oil change then jumped to using half a quart in 200 miles... took it to the dealer to have it checked out... they told me to ride it to the 5K service and not even look at the oil level.... they claimed they spoke to whomever at Harley they talk to and this is what they were told to do... supposedly, they claim they expect the consumption to level off at some point before it runs out of oil.... when I voiced my concern over this, the dealer to me that it's covered under warranty and if the motor blows up Harley will replace it.
They went on to confide that I wasn't the only bike they were watching for this type of oil consumption... all they did was a leak down test and a compression test which they said were well within spec... my fat bob came with synthetic oil as a factory fill... i think they suspect that the synthetic oil is slowing down the break in process...but they don't really have a grasp on why some bikes use oil...
your mileage may vary... best of luck
you sure it came with SYN3 factory fill? that's a CVO thing and they put stickers on the cases stating such..this would be the first non CVO I ever heard of joining the CVO SYN3 factory fill
In addition to the remarkably pathetic 1QT/1500 miles being acceptable per the bulletin, if I'm not mistaken, the other pathetic thing is that leak down of up to 25% is also withing spec, which is profoundly disturbing, and probably linked to the oil consumption
Campy Roadie (08-21-2018)
