Installing Fuel Moto's 120 Big-Bore Kit
Strych9, Interesting, your stock Cam pics.
This is the stock cam out of my '18 Heritage 114 Softail at about 1500 miles when the dealer installed the HD Torque cam. Discovered it when I inspected the cam about a week after the install. Showed both the Cam and pictures to the GM of the dealership and Service Mgr. Did not say much other than it was documented. I was and am concerned.
With roller cams cleanliness is a must. It doesn't take much to create problems that only increase with time. Thanks for the post.
If I had to guess, the cam mark could be caused by a small piece of debris that got caught between the cam lobe and the roller of the lifter. This would cause the roller to momentarily stop turning and drag the debris the full circumference of the lobe. That could be why there are marks on both. If you can catch a fingernail on any metal-to-metal contact surface that slide across each other, that's bad. It's a failure waiting to happen.
Another Old Timer (08-27-2018)
I've pulled so many cams that looked like (little scratches) that it ain't even funny. Same with the frosting on the lifter rollers which HD calls "normal". Usually nothing happens. Just looks bad.
The true test is to look at the lobes and ensure they are still consistent and not worn down. The rest is just well basically, cosmetic, and does not affect operation.
well, apologize and didn't intend to sidetrack this thread playing 20 questions...but is upgrading cam, bearing and SE lifters going to do anything to help prevent a recurrence? I was considering SE Stage 2 (because I have the ESP) and even more so now to have a look at the OEM wear on the parts and potentially ward off any future problems, but if the new parts are just as predisposed to premature and abnormal wear then probably just let it go as is, and let them fix any problems for my $50...might end the year with 30,000 miles and the 30K service would be when I would consider the upgrades and get done under the Winter discount service specials
The SE torque cam, although not as perky as many of the comparable aftermarket cams, will still give you considerably more power than the stock cam. If it is what you want to do I wouldn't hesitate to go for it.
mjwebb (08-27-2018)
