Front End Wobble
Front End Wobble
Yesterday I went on a ride and in a curve I got a weird feedback feeling through the handlebars. It felt like I was riding a rut. So on a straight away I loosened up and let go of the bars. The front end went into a shake/ wobble. It didn't take much more than putting my hands on the bars to stop it. Tire pressure is good.
I figure it's either wheel bearing or head bearings. I am not a bike mechanic so I am looking for input.
Bike is a 17 Ultra Limited with 9K miles. Bike is under warranty and will get a trip to the dealership for inspection.
Good indicator though and tried and true when dealing with these bikes. My vote is probably loose neck bearings. Too early for a tire typically. Inspect anyway.
Just maybe you or the previous owner ran through a pothole or road obstacle.Had Harley's that wobbled through fast corners
without ever finding the reason,just lived with it until we parted.Wobbling on the Straight is a serious problem that usually only comes with low tyre pressure or a dented rim.Raise the front wheel and look for deviations while spinning it.
If you see a kink take it to a rim straightening specialist.Seen this with a few salvage bikes I've restored. If it is not this,take it straight to the dealer and don't ride it until the fault is found.Good Luck!
No one ever specifies what speed this occurs so i must assume this must be the approx 30 mph wobble when u take your hands off the bars
Add 2 lbs of air to the front tire
so make it 38
it might take a lb more
All my FLH's have done this [6] and this is what fixes it
Neck bearings are adjusted properly - this was done first before upping the tire pressure
so make it 38
