Design changes in the 2019 cases?
Well. Twice, with 2 different vehicles I got notified that I was the recipient of damages from a class action law suit. I didn't even know about the suits. In both cases I received a 100K mile warranty on the engine.
hattitude (10-30-2018)
According to some HTT forum posts, there is a new oil pump backing plate, with the seal.... It is supposed to be a fix for sumping. But just like their other oil pump changes (what is it, 6 changes now), only time will tell.
There was one post, that basically said a MoCo Rep had to approve it being used on a sumping M8, before a dealer could order it..
Maybe it needed MoCo approval because it's a new part, held back for dealer warranty use only for now, but it appears to be listed as used on 2019 engines...
This is a post about the part #:
"There's a differant cover for the oil pump assembly that has an added seal, the the previous years didn't have.
2019 air cooled
11293 o-ring
62400206 cover oil pump assy
62400205 oil seal
2017 air cooled
11293 o-ring
62400125 cover oil pump assy"
And here's a pic of the new part:
2019 air cooled
11293 o-ring
62400205 oil seal
2017 air cooled
11293 o-ring
So do all 2019's have this new part (107,114,117)or is there a date range for the new parts, mine is August of 2018 and I was wondering if my 117 has any updates in it, I hope it does!
Received 47,784 Likes
Uncle Larry (10-30-2018)
People smarter than me, think one of the sumping triggers is when pressure variances in the sump area (poor design/manufacturing), interrupt the ability of the oil pump to scavenge the oil. Almost the same problem that happened to the Twin Cam and delayed its production almost a year. In that case, the MoCo caught it pre-production and decided to fix it properly. That is why one of the fixes Steve Cole does, is to machine some changes in the sump area and to the scavenging pick up. So based on that, I would guess the HD seal is supposed to stop/mitigate these pressures in the sump, that can interrupt the pump scavenging... I suspect Steve Cole is right and the MoCo is/has been searching for a fix that doesn't involve a change to the cases (???????)
