bummed,think my m8 sumped
#41
I have to disagree with this statement. It was actually guys like Steve Cole (TTS) who discovered sumping from running constant rpm/load for extended periods while building calibrations.
The dyno is a perfect testbed for sumping because every aspect of the running (rpm, load, temps, pressures, etc) is monitored and measured. All this info is right on the dyno operator’s monitor as the bike is run through its paces...all without breaking any speed laws or having traffic impede testing.
Don't sell the dyno short. There are very few diagnostic methods that can be better performed on the road by an enthusiast than a proper dyno and instrumentation run by someone who knows what he’s looking at and what to look for.
My experiences,
Bob
#42
My experiences,
Bob
klammer76 (09-25-2018)
#43
#44
My experiences,
Bob
Otherwise you are very likely to get the dreaded "we can't replicate the sumping problem" response. But those that feel differently can certainly rely on the dealership dyno to try and recreate your sumping condition, just be prepared for alot of frustration. I stand by my original recommendation that the simplest way to get HD to honor a warranty claim for an engine that's sumping.is to ride up to the dealership service door while the bike is sumping. I've been through enough sumping engines to have learned the lesson but everyone is free to do as they think is best for their situation.
GPHDXLC (09-21-2018)
#45
They will never get it to sump on a dyno or with a 15-20 min test ride. If they give you the bike back, do as I said early and ride the bike like I outlined (30-40 miles out/back on interstate followed by another 15-20 miles of back country twisties - Total 75-100 miles) with your final desination at the dealership. Its the ONLY way to get resolution short of breaking down on the side of the road. I’ve seen this happen too many times. Trust me on this recommendation. Anything less is wasting everyone’s time.
#46
Thursday they said the bike was ready to go,they couldn't recreate sumping,i told them to ride it like they stole it,run it hard because im going to when I get it back.they took it out for another ride and this time it did it,they said the oil pump went out and they are tearing into it finally,seems like they are dragging their feet,friends are telling me to call corporate and complain but I don't want to if they will fix it right,we'll see
#47
#48
Dealer just replaced oil pump and seal.
Heatwave, I called the dealer this morning to see how it went with my bike yesterday. He said it's done. I said "no s**t?, awesome. What did you do?" They said they replaced the oil pump and seal. I was a little concerned so I called the sales manager I bought the bike from and he said if I had any concerns, I could talk to the master tech when I show up. I logged into this forum, read SB 1450, and called them back. I asked service department if in deed it was sumping and they said if I pulled that much oil out of the CPS port (2 1/4 Qts), it must be. I then asked why they didnt follow the service bulletin and service rep now started to get a little pissy with me. He said "now who's fixing the bike here?" He said if I had any serious issues to the internals, the bike wouldn't be pulling the numbers it did on dyno. His other impressive comment to me was "my technician was pissing around with that bike for half a day before he decided to replace the oil pump and we changed the oil pump because we knew there would a problem". I presume he was implying they would have a "problem" with me. What do you recommend?
#49
If they drain more than 6 ounces out of the crankcase after your sump test ride.....well....its back to SB1450 to start all over again.
#50
Go ride the bike and enjoy it. Take it out and do the sump ride test I recommended earlier and finish your ride at the dealership that just did the work. Have them pull the Crank Position Sensor for themselves after your ride to confirm the new oil pump has resolved the sumping. If less than 5-6 ounces drops out of the crankcase after your “sump test ride”, you’ll likely never have to worry about sumping ever again.
