Tuner question.
Tuner question.
I just bought a 2018 road glide and I will eventually be completing the stage one upgrade but for now, I'm leaving it stock. I know that when the bike is stock from the factory, its very lean and was wondering if I installed the SESPT, would it make a noticeable difference with the bike stock? Like reducing the heat of the motor? Or should I just wait till I do the pipes and AC? Mind you id be looking into the power vision ect if it wouldn't void the warranty so my question is concerning the SESPT.
i just bought a 2018 road glide and i will eventually be completing the stage one upgrade but for now, i'm leaving it stock. I know that when the bike is stock from the factory, its very lean and was wondering if i installed the sespt, would it make a noticeable difference with the bike stock? Like reducing the heat of the motor? or should i just wait till i do the pipes and ac? mind you id be looking into the power vision ect if it wouldn't void the warranty so my question is concerning the sespt.
no
yes
Oz Dan (09-26-2018)
Agree with mjwebb. I did a Stage 1 heavy breather on my 18 SG and have vance and hines mufflers. Tuned with the SEPST by Harley. The air cleaner and tune did make a noticeable difference in torque and HP in certain RPM ranges. I'm going to put some power duals on soon and have then tweak the tune with the SEPST. The SEPST is far from ideal as a tuner. Once my 2 years is up I will go with a powervision and dyno tune for sure.
Well thanks for the info. I just dont want to void the warranty but also don't want to wait 2 years to do some upgrades. Are harley dealerships that **** when it comes to aftermarket tuners? And what if I just put some slipons on. According to the dealer i would still need a tuner. Otherwise you get alot of decal popping.
If your #1 concern is warranty, then slipons are as far as you should go. Keep your stock mufflers handy in case you need to take in for work until warranty expires. Decel popping shouldn't be a problem. It wasn't for me atleast. Maybe depends on slipons. If your in search of more sound, the slipons regardless of manufacturer won't do much. For that reason I added headers, high flow breather, and fp3 tuner. And honestly i can say I still haven't and probably won't find the sound I'm looking for. I thought I found it with the zombie baffles but for me they weren't worth the trade off for the significant loss on the low end. Not to mention a little obnoxious.
Harley is under federal court order that they MUST immediately and irrevocably void the warranty on any 2017+ bike if they have ANY knowledge that an aftermarket tuner was used.
If you use an aftermarket tuner, your warranty is gone, period.
FM500 (09-25-2018)
