Torque vs. Mufflers
Torque vs. Mufflers
i commented on the this topic, a while ago relative to my ‘17 RoadKing. My buttometer clearly noticed a reduction in Torque after installing SE Street Cannons. So then I added the K&N air filter, and did the HD stage 1 download. And it seemed happy.
But, I recently traded my ‘17 RoadKing on a new ‘17 Ultra Limited. It is still OEM stock. Now that I have passed the breakin period, I’ve started to twist the grip, Even with the extra weight of the Ultra Limited....Damn! My buttometer noticed an appreciable better kick in the butt than from my stage 1 ‘17 RoadKing.
Has anyone else noticed this impact from adding more free flowing slipons? Has there been any actual dyno testing to compare stock to HD Stage 1.
I’ve ordered the HD SE Street Canons, and Street tuner from Surdyke. As well I got the K&N from Amazon. But, now I’m wondering if I want to do these upgrades and take the torque hit.
Yes I've noticed forsure. While my headpipe is decatted and the bike has the SE8 447 TQ cam in it. The low end prefers the stock mufflers. Once I get the valve train rattle figured out. The stock mufflers will probably go back on. And the Eliminator 400's on to somebody else. When the baffles blew out of the Eliminator 400's a few months ago the bike fell flat on it's face. TQ and HP were gone. Proved to me the M8 has to have some back pressure. Was very clear.
But I would think the Street Canons would help with back pressure compared to my Eliminators 400's. No packing in them at all.
I think the Street Canons work great for torque, I picked up a nice gain down low over just the SEPST SE Stage 1 ecm calibration having them dyno tune with the SEPST...runs great in the 2000-4000 rpm range..I din't get a stock dyno run but it would be below the red Stage 1 ecm calibration
I played a little with different combos all butt dynoed !
#1 Arlen ness big sucker and powervision stock improved map.
This still had the bottom end torque of a stock setup. 2 up torque/power very good
#2 Added CVO mufflers with the Fullsac 2.25 Baffles/techmat, Autotuned powervision map
Bottom end suffered a good bit. Did'nt feel the choking off of the stock mufflers in the mid to upper end. Exhaust note louder, not impressed.
#3 Decatted stock headpipe with the Fullsac 2.25 Baffles/techmat.
No performance change from #2. Deeper exhaust note. Pops when accelerating letting off the gas sometimes (this sucks).
#4 Decatted stock headpipe with the Fullsac 1.75 Baffles/techmat.
Regained some bottom end. Still popped. Exhaust note better then stock. But still don't sound like a Harley
#5 Decatted stock headpipe with the stock mufflers.
Back to the bottom end torque of a stock setup. 2 up torque/power very good. Still pops once in a while.
Actually like the quiet of this setup. 2 up riding more enjoyable.
Like the #5 setup the best. Heat is gone from the decat. Never could dial out the gear shift exhaust pop once in a while. But being careful about the shift points I could stop it. I think taking the cat out of the head pipe with a stock setup is not the best idea. Exhaust is probably too free flowing. 28,000 miles on the bike now.
S&S 365C cam and other goodies on the shelf for winter work. And I'll either put the stock headpipe on with cat. Or most likely pickup the fullsac headpipe.
I have had different size mufflers on all kinds of older and new Harleys, and most new bikes with V & H. I have never heard of anyone "blowing their baffles out "if installed properly. I'm sure V & H would replace them.
I'm running the V & H Eliminator 400's currently. Had a good dyno tune with a TTS tuner and have 142 torque.
correct..doesn't the Ultra twin cooled have higher compression..perhaps your perception is reality with the 'butt ometer' because of that
mjwebb (10-01-2018)
