S&S big bore kit 124!!!!
#41
Along with a better pump and plate in the S&S kit. The cylinders are different manufactures. The S&S cylinders are made in the USA and it's stated so. The other cylinders that a lot of the venders are pushing are not. Having a hard time finding exactly where over seas but it isn't in the USA. You also get valve springs, seats and seals, and billet anti rotation blocks
#42
#43
I think any good machine shop could do it, but Steve Cole told me to have the excess trimmed from the bottom of the cylinders, so it would probably be better if they have a CNC. If I need it, I'm doing a 117" using stock cylinders over bored, I will more than likely take it to Patrick Racing. Heads too, if they need to be planed to adjust the combustion chambers. He's done some work for me and he does good work. I'm shooting for an 11:1 static compression. I'm still trying to decide what to do for a throttle body, but I'm leaning toward stock with the new SE manifold. I hope that Steve will have his dyno set up about the same time I get this done so that we can test some cams. Should be interesting!
OldMike (02-15-2019)
#44
The overall numbers themselves would be relative to the components used, both kits offer really good performance increases; results depend on the peripherals that are used in each overall combination. As far as the piston/cylinders; the FM kits use a custom proprietary piston by CP Carrillo, for cylinders we have used several different suppliers for M8 cylinders, all of very good quality. Our current 124/128 cylinders are now supplied from a single channel and a preferred manufacturer we work closely with, a great company not far from us based out of Viola, WI.
__________________
Jamie Long / Fuel Moto USA
The USA's Leader V-Twin EFI & Performance www.fuelmotousa.com
Contact 920-423-3309
Email jamie@fuelmotousa.com
#45
#46
As mentioned by $tonecold, You just can't beat Fuel Moto's support. Hands down, undisputed, they are the absolute best aftermarket company to work with. Their products are all top notch and will put a smile on your face. If you have issues, call them. They actually care after the sale. You won't find that anywhere else or at least I haven't been able too. The best part about them in my opinion, is they are a one stop shop company. I buy all my critical components from them. And guess what, it's been tried and tested by Fuel Moto. It makes modification that should be fun stay fun...
#47
#49
#50
Thanks for the sheet. I just received the tracking number for my 124 kit yesterday. Did you put in new valve springs? If so what did you use?
