Synthetic or regular oil?
I have a 2017 Road King with the Milwaukee Eight engine. I'm putting the bike into winter storage and was asked which oil to use for oil change. I was told no real difference between synthetic and regular oil. Both are good for 5000 miles. What are the pros and cons of both oils for the Milwaukee Eight?
The following 3 users liked this post by mjwebb:
No such luck. I'm going to say this just once (in this thread)...
Maximum engine wear occurs at startup. Synthetic oils are better at flowing during startup and thus protect your engine better during that time, period.
The only reasons to go with conventional oil after the initial break-in period are:
1. Your a cheap a$$hole.
2. You don't give a damn about your bike.
3. You're a Luddite and/or can't understand what I just said.
4. You own your own oil well.
That should end the conversation, period.
Ludwig von Buzzthoven (10-12-2018)
"Most engine wear takes place in the first minutes after cold-starting, as a result of the time it takes for oil to circulate to all parts. Thus wear prevention is mainly a function of the additive package, and not of the molecular origin of the oil itself."
https://www.cycleworld.com/2014/07/0...l-or-petroleum
Uncle Larry (10-12-2018)
Received 5,388 Likes
