Shifting issues w/ 2019 Street Bob
Agreed
Give the dealer some slack "you can't fix what ain't broken". Until they can replicate the problem what do you expect them to do. I guess most HD critics figure that the dealerships just leave the bike in the corner, don't ride it and then tell the customer they can't replicate the issue.
i might embarrass myself with this response but i had a 1990 Suzuki intruder with the same symptoms . Turns out the shift linkage was whacking into the aftermarket pipes when things expanded when hot. I know apples and oranges but maybe its not an adjustment its something changing with the heat.
i will go away now!
Mazz
i will go away now!
Mazz
i will go away now!
Mazz
i will go away now!
Mazz
Yes sir, I checked all the fluid levels. Eveyrthing is at the appropriate level and clean. I'm really thinking/hoping somethign is going on with the clutch pack (as eveidenced by the scratch marks) and a simple swap-out or rebuild of the clutch will resolve the issue. Harley won't touch it, however, until they can verify a problem. I'll keep you guys updated as to how this plays out. Thanks!
Agreed, they could be jerks about it... and I am prepared. I've adjusted these clutches at least 20 times over the past seven years and can happily speak to the dealearship about what happened. The marring to the nut happened while attempting to de-torque it. I wanted to see where the factory clutch was set at so I used an 11/16 box-end wrench on the nut while holding the pushrod with an allen key. This was a foolish idea becaus the factory nut was on their realy good and the box-end slipped. I aborted this attempt and removed the nut properly with an 11/16 socket and never did find out where the factory had the pushrod set. When re-torquing the jamnut I put the bike in gear, have my son sit on the bike and hold the front/rear brakes and I use the 11/16 socket on a torque wrench set to 10 N-m.
