M8 sputers and stalls when stopping
my 2018 road glide is sometimes stalling when coming to a stop . This happens when it is warmed up . It seems the idle sputters and dips then sometimes it stalls .any ideas what it may be ? I changed the plugs ,wires , air filter and put in fresh gas and no luck . The bike has 10k on it . Thanks in advance . |
Bad switch pack on left bar? Does it start in gear? Will the eitms work in gear?
Any check engine lights?
You're changing parts out on a bike that's under warranty?
Why? |
Originally Posted by Tired
(Post 17804143)
Why? |
The bike won’t start in gear and I changed plugs , wires and air filter to avoid going to dealer and losing bike for a few weeks . I have not done any warranty ending modifications, the bike is stock . |
Originally Posted by 8828alex
(Post 17804177)
Thanks for info , I think it is just an idle issue. I will call dealer and bring it in . I really try to avoid going there , the last time I had it there was with my 16’ RGU and they had it there for almost 2 weeks for a neutral switch . |
(Post 17804177)
Thanks for info , I think it is just an idle issue. I will call dealer and bring it in . I really try to avoid going there , the last time I had it there was with my 16’ RGU and they had it there for almost 2 weeks for a neutral switch . Call dealer in advance. 30 minutes to replace switch and lever. There's a service bulletin on it. |
© 2024 MH Sub I, LLC dba Internet Brands
