2018 Fat Bob 107 stage 2 - to Dyno or not???
Hey guys,
I wanted your feedback and opinion regarding doing a dyno tune. I just recently got my bike back from Harley after they did a stage 2 upgrade. They tuned the bike there with SE tuner but not with dyno as they do not do dyno tuning. Bike is running way better then stock, some exhaust pops here and there but not all of the time. My question is. Will the cost to Dyno tune be worth it in regards to the bike performing better and getting more out of stage 2 and upgrades over the SE tune or does the SE tune come close enough? The local dyno tuner does not use the SE tuner so i would have to get another one. With dyno tune and tuner its about $800. Your thoughts or experiences would be much appreciated. Thank you in advance...
Hey guys,
I agree with Webby. Give it a few hundred miles too. Your cam has to break in, and your adaptive ECU has to make adjustments to your ride habits. If you’re still not satisfied, do the auto tune runs. I’ve had Dynos on bikes in the past and they are great, but my SE Stage 2 is running very well with the basic tune. Twin Cam motors needed to be rescued from factory tunes, but the M8 is efficient enough that the factory tunes are pretty solid.
Also you bothered to have a warranty friendly mod done to your bike, if you use a different tuner you’re basically voiding your warranty and if you were going to do that you might as well have gone with a totally different cam/tuner to begin with. I’d suggest giving what you have got a full try first.
If your warranty isn't an issue and you have a good dyno tuner then it's the cherry on top of your upgrades. I'm only speaking on my twin cam experience like these guys have said that the m8 is pretty good with factory tune. Is there more on the table ,sure. I will say the money I spent, 300 for the direct link and 600 for the tune, was the best money I've spent on the bike to date...night and day honestly. You're in a different situation and honestly if I were in your place I think I'd ride it until my warranty was up then I'd uncork it.
Hey guys,
I recommend always getting a custom tune. You should see improvements across the board, but more importantly your A/F ratio will be correct. In my opinion, it's worth it.
mjwebb (11-20-2018)
tripleb1911
08-19-2016 02:45 PM
