FM 117” kit with S&S 475 cam build
#51
Had a delay due to chasing an intake leak. Found it and completed the build today. Test ride is tomorrow. My tech says I gotta put 500 miles or so on it before I Dyno it, so it make be another week or so before I do that. Also, I have some extra valve train noise, so I may take the pushrods and lifters out and try that again. Other than that, sounds good so far!
https://university.fuelmotousa.com/h...-myths-truths-
Steve N, (02-15-2019)
#52
I follow this guy http://www.mototuneusa.com/break_in_secrets.htm.
Ran them in like that long before I'd even heard of him too.
Trainwreck keep us posted it should be a good'un.
FLTRI17 (01-25-2019)
#53
#54
#56
#57
#58
There are lots of ways to break in an engine. The one thing that gets skipped in most of these discussions is how was the engine assembled! You could use the same break in, on different assembled engines and come up with different results. If they were all assembled the same, it would be much different. As for riding an untuned bike and hurting the engine.......... yes, its possible but if you have a late model fuel injected engine its highly unlikely, unless the assemble of the engine was not so good. The ECM will start adjusting the fuel and timing as soon as the engine warms up. So while it may not be the best possible fuel mixture and timing, if you use a little common sense you will be fine. The entire idea of engine break in is to allow the parts to run in and stay lucubrated. A few short warmup cycles is very important on an air cooled engine. After that you want to run the engine under load to help get the rings seated. With today's rings and cylinder finishes it is nothing like the old days where it takes several hours of running to get the rings seated.
Ridetothehill (01-14-2019)
#59
#60
Thank you Steve. Do you agree with running hard with full acceleration and decal while under load and after sufficiently warmed up? According to this theory or practice, of which I think to be a good one, the run in recommendation from the manufacturer does not allow sufficient gas pressure on the rings to properly seat and wear them in along the full circumference.
